Drag Racing Tech
updated pics of rear tire clearance.
Old 09-21-2009, 06:32 PM
03 BUSA's Avatar
Default updated pics of rear tire clearance.
I went in 3 rounds on the LCA's on both sides. Let me know if this looks better. I am assuming since I went in both sides equally the alignment numbers should not of changed. Correct??
Here is the right side of the car.
Attached Thumbnails updated pics of rear tire clearance.-clearance013.jpg   updated pics of rear tire clearance.-clearance014.jpg
Old 09-21-2009, 06:34 PM
03 BUSA's Avatar
Here are the left side pics.
Attached Thumbnails updated pics of rear tire clearance.-clearance016.jpg   updated pics of rear tire clearance.-clearance018.jpg
Old 09-21-2009, 06:59 PM
03 BUSA's Avatar
The left side looks perfect to me. The right front is my main concern. I beat it in the best I could without going overboard just still think it might be a hair close yet.
Old 09-21-2009, 09:15 PM
SPEEDYws6's Avatar
It may rub a little with a hard turn, but I bet it will be fine going down the track.
Old 09-21-2009, 09:46 PM
SuperSlow02's Avatar
It looks like I have less clearance then that, and I dont have any rub issues, Im running an ET street though
Old 09-22-2009, 06:51 AM
03 BUSA's Avatar
Thanks guys.
Old 09-26-2009, 09:33 AM
renee00formula's Avatar
Don't bother setting up your LCA to keep the tire even in the wheelwell. Set it up so that you have your drive wheels square to your front wheels. With these cars the body isn't always square, so if you are adjusting it based on the wheelwell you might end up with a rear that dogtracks. Just measure center cap to center cap and that should get you pointed in the right direction.
Old 09-27-2009, 08:47 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
You have plenty of clearance now. I would check the inside wheel well to see if you have clearance there though. With a spool, the tire has a tendency to wad up and rub while turning sharp. You don't want to slice a new set of tires.
If you don't square up the rear, you'll know it the first time the front tires come off the ground at the hit.
Old 09-29-2009, 10:29 AM
BMR Tech's Avatar
Looks a little close but it should be ok.....
One thing to also remember is the tire growth will also be affected by your trap MPH so what might clear fine at 100 mph might not be so great at 130 MPH....
Old 09-29-2009, 08:35 PM
1BADAIR's Avatar
might work. I can't get mine to stop rubbing. I think my problem is the poly bushings flexing every time i shift though
