Drag Racing Tech
Strange coilovers and shocks came today.
Old 09-30-2009, 05:20 PM
boostnificent's Avatar
Default Strange coilovers and shocks came today.
The UPS guy dropped these off today. I can't wait to get them on. I just have a couple of other things to aquire so these can go on. Anyone else running these? What are your compression and rebound settings?
Old 09-30-2009, 07:45 PM
DTB_LS1's Avatar
I have them on my m6 cam only car. On the street I run the extension at about 4-5 and the rebound at around 6 on the front and the rears I run at 6.
At the track I front the extension at 0 and the rebound at 3-4 and I run the rears at 5-6.
Old 09-30-2009, 08:34 PM
cool thanks for the info. Did you see a big difference after you got them installed?
Old 09-30-2009, 08:44 PM
358chevycamaro's Avatar
I have the singles on the front and it is a night and day difference! I run the 275lbs spring and between 2 clicks from full loose to full loose depending upon the track condtions.
Old 09-30-2009, 08:46 PM
chvypwr31's Avatar
heyyy i didnt get an adjuster wrench when i got mine, i had to make my own.
Old 09-30-2009, 09:41 PM
thats just how i roll. lol!! no i was suprised it was in there. i thought i was going to have to buy one or make one.
Old 09-30-2009, 10:30 PM
chvypwr31's Avatar
we use a tool that looks very similar to an adjuster wrench to tighten our tool holders for our cnc machines so i just modified one of those.
Old 09-30-2009, 10:44 PM
Sideways240sx's Avatar
i did not get the wrench either.. I had some from previous coilovers on other cars.
I have them on the front of my car, but have never run the car with them on yet.
Looking forward to it next year.
Chris
Old 09-30-2009, 11:13 PM
transam69230's Avatar
Your either going to have to make an extension for that wrench or have the hulk come over and tighten those up for you cause its a pain. You need the longest pair of channel locks you can find to turn those *****. It is hard and it sucks!
Old 10-01-2009, 12:36 AM
Mikey 97Z M6's Avatar
I just got the Strange single adjustables for the front. Made my first pass with them last Saturday and they knocked off .20 from my previous best quarter mile ET. Sixty foot times droped from mid 1.7's to mid/high 1.6's on a M6 car.
To make the height adjustment go easier, use some WD-40 on the threads. It makes a world of difference.
Mike
Old 10-01-2009, 12:42 AM
studderin's Avatar
get the bearing kit for the front and they are way easier to adjust.
you can use you stock front springs they bolt on, And the lower perches you have to cut the bottom off. But I used them fine.
http://i2.photobucket.com/albums/y11...n/IMG_1337.jpg
http://i2.photobucket.com/albums/y11...n/IMG_1322.jpg
Old 10-01-2009, 07:52 AM
DTB_LS1's Avatar
I went from a Koni 4/4 setup to my current Strange setup and yes I felt a huge difference.
Old 10-01-2009, 01:12 PM
7 Second Club
ty_ty13's Avatar
front- 5ext 7comp
back- 10ext 9 comp the left and right are a little different on comp....
Old 10-01-2009, 10:08 PM
these are next w/ a 150 lb to 175 lb spring. probably the 175 for street use and once it is mainly a track car and weekend warrior i will switch to the 150 lb.
Old 10-02-2009, 08:13 AM
z28rob18's Avatar
i didnt get an adjuster wit mine either. what'd yall make to adjust them with?
Quick Reply: Strange coilovers and shocks came today.
