Drag Racing Tech
9' or 9.5" ford for 4th gen BBC heavy drag radial cars
Old 10-07-2009, 09:45 AM
7 Second Club
ty_ty13's Avatar
Default 9' or 9.5" ford for 4th gen BBC heavy drag radial cars
anyone having enough problems out of their 9" behind a hi torque motor (600+ ci) that they are considering a 9.5" ?
just curious... i know in my friends stick car thats got a 598 on dope he uses a 9.5" to keep down some maintenance (spelling?)
Old 10-07-2009, 09:59 AM
Shawn @ VA Speed's Avatar
many-many 6sec 3200lb cars with 9'' rears and no issues.just be sure to run a pro gear
Old 10-07-2009, 10:01 AM
Race your car!
JL ws-6's Avatar
With the shock a 598 nitrous motor would have nothing is gonna survive that forever!
9 inch with 40 spline axles and a steel spool and pro gear,should be good to go. Just get a center section with the big pinion support and all that.
7 Second Club
ty_ty13's Avatar
when you say no issues.... meaning no broken ring and pinions over the course of a whole racing season and a fresh 1 each winter?
Old 10-07-2009, 10:10 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I know a few guys running 35 spline 9" stuff plus pro gears running the high 7's in non-LSx BBC setups.
Old 10-07-2009, 11:19 AM
6 & 8 Second Club
mrdragster1970's Avatar
My car is still using a 9". 6.50 @ 213 times many many pass'.
As mentioned, nothing lasts forever at these power levels.
I just replaced gears a couple of weeks ago. About 50 pass' and it was very worn out.
It still worked fine, but it was definitely ugly looking.
I thought about trying a 9.5" and I probably will make the change if I ever finish my blower engine.
Most of the guys still use 9", newer cars seem to be using 9.5" more & more.
The only way to know is look and judge the life cycle you are getting.
Old 10-07-2009, 01:13 PM
tomcowle's Avatar
When we dabbled with a SuperStock/O Impala 283ci/jerico we ran a dana 60 and we'd get maybe 35 hits on it before it broke.
Old 10-07-2009, 01:22 PM
no issues means-no broken components for atleast a year.
we used to leave at 5600 with my twin turbo smallblock in my 10.5 car-several 1.14 60's at 3000+ lbs,over 500 passes on the same ring and pinion-in fact that ring and pinion has been in ther since 2001.plan on using the same rear behind my twin turbo 672bbc,if it breaks i will then go to a MW 11''.
There are circumstances that you need bigger-stick cars are much more abusive on rears,as well as big tire cars.If you rattle the tires alot you can break the rear as well.
hell Dave Hinzman has a bbc f3 drag radial car that run 7.30's or so and has a ford 8.8 in it.
Old 10-07-2009, 01:24 PM
7 Second Club
ty_ty13's Avatar
thats exactically what i dont want... needs to get atleast 125 runs before it pops to be pretty durable to me. granted i probably wouldn't put that many runs on it in a season... but you never know...
Old 10-07-2009, 01:26 PM
7 Second Club
ty_ty13's Avatar
i know its all relative but i just wanted to see what others thought.
Old 10-07-2009, 01:43 PM
DanZ28's Avatar
I'm running a 9" with my BBC, but i don't have an off the shelf 9". I also have the best 9" center section MW sells, 40 spline and the big ball bearing pinion, with 3.40 pro gears. I really don't expect to have any issues but it doesn't hurt to over do it either. I also run a DR and forced inducted so i won't hit the tires as hard as you...
Steve Jackson still on a 8.8" rear with I'm sure 3000+ HP BBC F3R too...
Old 10-07-2009, 01:56 PM
mdacton's Avatar
close to a whole season in a car running high 3's in 1/8
Old 10-07-2009, 09:02 PM
LS1TECH Sponsor
Steve Burger's Avatar
we can set you up with a rear that should last a season on a sinlge gear. We have a lot of cars doing that. ~700 CI and 4 stages of spray and we can get a season out of a rear.
