Drag Racing Tech
Where to source new suspension bolts
Old 10-31-2009, 09:11 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,097 Likes on 721 Posts
Default Where to source new suspension bolts
I've got most of the rear suspension bolted up into the 2000 Z/28, but I'm liking the idea of running all new bolts for the lca's and phb. Any suggestions?
Also anyone know what the bolt size was stock for the cross member that sat about 2 feet in front of the diff?
Old 10-31-2009, 11:17 PM
K9Kev's Avatar
John,
I need some for my front K-member as well. I was looking at some of the sponsors sites and, if I remember correct, both BMR and Wolfe can supply you with what you be needin.
Good luck,
Kev
Old 11-01-2009, 09:42 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Spohn has them. Check their site.
Old 11-01-2009, 12:44 PM
LS1Tech Co-Founder
Thanks guys.
Old 11-01-2009, 12:51 PM
WE TODD DID's Avatar
Grade 8 bolts is what any of the above manufacturers will supply you with. You can get them from your local hardware store. Remember to get grade 8 nuts, and hardened washers as well.
Old 11-01-2009, 02:01 PM
LS1Tech Co-Founder
I've got a Menards and Home Depot by me, and they are hit or miss.
Old 11-01-2009, 03:18 PM
JUICED96Z's Avatar
I have got lucky at Sears Hardware... they tend to have the big bolts that Home Depot and them don't have... big enough to replace bolts on my cherry picker that were not in the box...
Old 11-01-2009, 06:45 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Try your local Napa shop as they often carry all Grade 8 stuff. I just put on my QA1's and used all Grade 8 + Nylon Locking Nuts and washers.
Old 11-01-2009, 06:56 PM
spaulding's Avatar
i had gotten all new k member and front lca bolts right from the dealer then,bmr has the rear lca stuff or i like to go to mcmastercarr.com for all my odd ball hardware needs they have just about anything you would want and yes grade 8 is the way to go for all the susp stuff the rear cross member is prolly m10x1.25 but im not sure ill check that tomorow in my box o spare bolts
Old 11-01-2009, 07:39 PM
JUICED96Z's Avatar
I went a while back and the told me to get the big stuff you have to go to their local ware house that distributes to the local stores to get them. Im sure they have the factory stuff but if you went to the larger LCA bolts I doubt it.
Old 11-01-2009, 08:47 PM
LS1Tech Co-Founder
I've used McMaster Carr before, very handy. I'm probably just going to get the bolts I need from Spohn.
Old 11-01-2009, 10:29 PM
Lowes usually has a nice selection of grade 8 hardware.
Old 11-02-2009, 10:11 AM
LS1Tech Co-Founder
I think I will get them from Madman, my list of needed bolts is getting longer and longer. I've got all of the rear suspension bolted in except for the drag sway bar. Looks purty, I will take pics.
Old 11-03-2009, 08:13 PM
Tenured Member
SMOKY's Avatar
I go to carquest for my bolts theyve been cheaper than sears and menards and if they dont have it they can usually get it. It also helps that the warehouse is off 53 in bolingbrook by me.
Old 11-08-2009, 08:44 PM
LS1Tech Co-Founder
Hmmm I'll have to check out Menards I have one that is about 2 miles away.
I bolted in the UMI rear drag bar, looks very nice. Now I just have to find a handful of missing bolts and the car is a rock solid roller.
Old 11-09-2009, 10:29 AM
LS1Tech Co-Founder
I just need three nuts to complete the back half, and of course some brakes.
Old 11-10-2009, 07:52 AM
mad_steve's Avatar
We typically drill out most of the holes for the LCA's and PHB etc. to 1/2" and use grade 8 bolts from Fastenal, when replacing the stock bolts. Remember to use fine thread bolts and to have all shank through most of the bushing(s). You'll have to get a bolt that has enough bushing to go all of the way through your bushing (best if it will go through the bracket as well) then cut it down so the excess threads aren't in the way.
Old 11-27-2009, 08:33 PM
TJ
TJ's Avatar
if you dont have an available fastener store, look at the john deere or CAT dealers.
they stock grade 8 and 10.9 property class metric bolts in bulk.
