look at these launch videos any suggestion
here is a couple of my passes. any suggestions on changing setup that might cut some more time
http://videos.streetfire.net/video/f...ass_717960.htm
http://videos.streetfire.net/video/0...-SS_157326.htm
QA1 12 way adjustible front and rear
BMR trac pack
BMR adjustible race LCA's (rod ends)
Wolfe racecraft rear swaybar
BMR adjustible phr (rod ends)
28 in et drags
v6 rear springs
removed front swaybar
settings
-1.5 pinion angle
6 front 10 rear on shocks
12psi on slicks
BMR trac pack
28 in et drags
v6 rear springs
settings
-1.5 pinion angle
12psi on slicks
You want him to run ET Drags at 18 psi? No way. Honestly, I was thinking that 12 was a bit high, but it hooks so I would leave tire pressure where it is. If it were mine, I would loosen the front shocks a click or 2 and go from there. It looks like they are stopping the momentum and bringing the car down early.
those slicks are equal to a quick time pro i run mine at 18 in a lighter car the larger the tire the less air it need i run my 33 15 15 slicks at 8 psi and my 32 14 15 at 9-10 get some pics of the tires on lauch to much wrinkle is bad just try 12 and than 16 back to back see what happens the small tire heavy car needs a little more air
appreciate the responses. we are heading to Texas Motorplex (Ennis) saturday and i wanted to see if there were some ways to cut little more time off before i start on more mods
I run 18PSI on the MT 17" drag radials. On slicks I run about 12 PSI. I can run lower on the slicks but I only dead hook with them anyway. I think I ran them with 20 once and they still dead hooked but it depends on the track, temps and prep. I've run the slicks as low as 10PSI but I noticed they were moving on the rims. I went with tubes and screws but to be honest I don't have to push below 12PSI for any reason.
