Drag Racing Tech
Where to go from here?
Old 11-09-2009, 12:10 AM
spoonraker's Avatar
Default Where to go from here?
The car currently has...
-3 pt SFCs welded
-MWCP Adjustable LCAs
-MWCP Adjustable panhard bar
-MWCP Adjustable tq arm
-Strange 12-bolt (spool, 35 spline axles, lca brackets, etc.)
-Hot cam/lid/ls6 intake (needs a tune badly, only makes 337HP currently)
Things that definitely WILL be done...
-Slicks/skinnies
-TH350 or 400 manual valve body/t-brake (I would go 350 but I might just get an amazing deal on a 400)
-150 shot of nitrous
-Tune
I'm hoping for just a consistent 10 second car. So where would you go next? I was thinking finishing out the suspension with adjustable shocks and new springs and a rear drag bar. I'm sure a driveshaft would be a good idea too. I figured I would have enough power for 10s with a good tune on what I have now and the nitrous...
Thoughts?
Old 11-09-2009, 02:01 AM
ZV8
ZV8's Avatar
since this will basicaly be a track car after you switch to a TH350 or 400, then you should get a cage and remove most of the interior for weight reduction. relocate battery to the back, etc. where you live might be ok to remove A/C which will come in handy when you need to work on that side of the engine for headers, plugs etc.
Old 11-09-2009, 11:48 AM
spoonraker's Avatar
Yeah I forgot to mention that a cage will definitely be installed sometime. I don't think I'll be able to make a nitrous pass at the track without one if it goes as quick as I'm hoping.
I've been thinking about removing the AC for a while, I really never use it. It gets hot as hell here in the summers, but it does have t-tops and it's not like it's a daily driver or anything, and if I do ever take it out just to cruise a little bit I have t-tops.
Old 11-09-2009, 01:47 PM
LS1TECH Sponsor
Steve Burger's Avatar
Sounds like you are on the right track.
Do you plan to stay in the 10s or go 9s at some point?
Where are you at in Lincoln? I get out there a lot.
Old 11-09-2009, 02:32 PM
spoonraker's Avatar
I'm in Lincoln. Next season I'll probably be out at MAM quite a bit for the friday night street-racing. Shame there's no 1/4 mile tracks close to here. I think KCIR is probably the best track that is relatively close and it's 3.5 hours away.
I honestly planned on cracking 10s and staying there when I first started, but this is coming together quicker than I thought it would, so maybe after next season I'll be looking to go even faster. I would like to put a more aggressive cam in (i bought the car with this silly hotcam in it) and a set of heads.
Old 11-09-2009, 02:37 PM
night ryder's Avatar
i would buy a ms4, trex, or polluter cam and then save up for some heads before the nitrous. gets annoying real fast filling bottles.
Old 11-09-2009, 03:50 PM
LS1TECH Sponsor
That's why I asked. I see a lot of people get a 6 point installed then decide to go faster. If 9's are even in the thought process I would go 10 point cage. Add a good set of shocks, (AFCO had a price drop and are very affordable). We can get those for you at a very good price. Add a drag bar and drive shaft as you mentioned. With the T Brake you should pick up quite a bit NA.
Let me know if we can help.
