Drag Racing Tech
Cutting below front windshield...
Old 11-09-2009, 05:15 PM
NSTIGATR's Avatar
Default Cutting below front windshield...
got the LT1 down to 2975lbs. tryin to get down some more. the sheetmetal that is directly under the front windshield that people cut out when runnin carbs where the plastic piece rests that covers the wipers.... can you remove it on a street driven vehicle. its not a DD but is mostly a street toy. there are no wipers so if it can go imma cut it out.
Old 11-09-2009, 05:32 PM
BassProCamaro97's Avatar
Yup. You sure can.
Take a look at my link to see a few photos of what I have hacked out.
Some have removed a lot more then I have.
~Jim~
Old 11-09-2009, 05:50 PM
NSTIGATR's Avatar
very nice.... time to go out in the shop lol
Old 11-09-2009, 06:09 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Just be careful to not crack the windshield (speaking from experience). But then again I was going to replace it anyway, and I did use a reciprocating saw. If I had it to do again, I'd either use a torch or a cut-off wheel.
Old 11-09-2009, 06:11 PM
SSPerformance's Avatar
plasma cutter workes nice on it
Old 11-09-2009, 07:53 PM
Taubr Unit's Avatar
check my sig, did it all with a lot of pics in there. I have more on my computer if u want more.
Old 11-10-2009, 08:24 AM
NSTIGATR's Avatar
thanks fellas.. yea plasma cutter is at the pops house so imma be using a cutoff wheel
Old 11-10-2009, 08:44 AM
Internet Mechanic
BlackScreaminMachine's Avatar
What weight reduction have you done so far? Since my answer had already been taken
Old 11-10-2009, 10:36 PM
NSTIGATR's Avatar
all the weight reduction possible for the most part other than drag brakes cause i drive the car mainly on the street. next will be tubular control arms, manual rack, and tubular k member.
no power steering, no a/c, no hvac at all, no back seats, door bars, bumper supports, extra metal brackets and tabs cut off, airbags, grant steering wheel, air bag brackets, abs delete and sjm install, seat belts removed and rci belts installed, carpet insulation, no frt sway bar or brackets, inner fender sheetmetal removed, now cowl sheetmetal removed, sure theres more, but just added a nitrous bottle and hardware today....
Old 11-10-2009, 11:00 PM
358chevycamaro's Avatar
I would reccomend a metabo with a cutting wheel, a plasma cutter can build up a little to much heat if you want to trim it close to the windshield like I did, and that heat can crack the windshield. Cut it all out to the seam on the firewall, I did!
Old 11-11-2009, 12:59 PM
tim99ws6's Avatar
We used a cut-off wheel on mine.
Old 11-12-2009, 06:13 PM
'Bird Director
y2k_ta's Avatar
I totally forgot about using a plasma cutter....I'd have to agree with you! I use one at work all the time now.
