Drag Racing Tech
current time (11.66) wanting 11.30's??
Old 11-12-2009, 01:41 AM
slowlsx's Avatar
Default current time (11.66) wanting 11.30's??
ok guys i have 2000 camaro. i have ran the best being a 11.66 at 117 with the DA at 1950 with a unknown 60' because the 60' didnt come up but it has seen 1.63 with a slower time. here are my my current modifications done to the car.
stock 347 bottom end
410's
LT's
circle D 4c(3600ish)
prc 5.3 heads
231/234 Tsp cam
stock intake
UD pulley
torque Arm
lca's
what other modifications do you think i can use to get this car in the 11.30's constistently on motor? i already have nitrous on the car but i want 11.30's NA.
Old 11-12-2009, 06:59 AM
Detroitmuscle's Avatar
What are the tires and weight of the car? The first thing I see off teh bat is the stock intake, throw an LS6 on that sucker and that should net you an few hp.
Old 11-12-2009, 09:17 AM
Intercooler2's Avatar
I went 11.79 SI with most of your same mods but 4.10's. I have less cam and some issues and went 11.46. Maybe it is your intake.
Old 11-12-2009, 01:54 PM
slowlsx's Avatar
the car is full wheight and running a 27/10.5 et street with about 15psi and it spun cause it left pretty hard.nothing has ben removed except for me having convo pros all the way around... what about a fast 92? any worthy gains over a ls6
Old 11-12-2009, 01:58 PM
slowlsx's Avatar
i am also having issues as well. im getting constant knock right at the line then it decrease thru the pass. so im leaving with about 22* and by the end of the run im at about 26*
ive tried to reduce timing by the amount of knock i have but it still does it so im gonna try some different things with the tune on friday and see what happens.
im going to try out a fast 92 since i have one on myy other car and see how that works out. 2-3 tenths possible with a fast if its hurting me?
Old 11-12-2009, 02:35 PM
I can't say the FAST did anything for me.
Old 11-12-2009, 06:58 PM
slowlsx's Avatar
what knda of 60's are you gettng? We seem to have the same converter.
Old 11-14-2009, 07:28 AM
358chevycamaro's Avatar
Take a few hundred lbs out. It's free and you can start running 11.20-30's in no time!
Old 11-14-2009, 09:24 AM
Best is 1.55 60'. I think I can get a 1.50 on a perfect pass with it.
Old 11-14-2009, 04:25 PM
slowlsx's Avatar
im down for that! how could i begin to go about taking wheight out without tearing up the car?
i got a PB last night with still a little bit of knock due to my sensors being sensitive.
60' 1.61
1/8 7.405
1/4 11.61
MPH 117.28
These Et streets are not cutting it for me so im looking for a drag radial because i know they hook much better!!
To do list
Drop some wheight
Fast or Ls6
different tire
loosen up the converter. im looking for 1.4 60's
possible 10's??
Old 11-14-2009, 08:00 PM
JaSSon's Avatar
Ported Fast 92/92, and a good rearend with a spool. You would be surprised what a posi unit goes through in the first 60'.
