quickest tire for my setup
im trying to make the s.i list and my best run to date is 11.77@115.30 1.60'
right now im running 255/50/16 mt drag radials on snowflakes.im going to be picking up some 15" rims soon and want to know what would get me down the 1/4 faster.
should i go with
hoosier QTP pro's-26 X 9.50-15 weight 17lbs
hoosier slicks-----26.0/9.0-15 weight 18lbs
mt slicks---------26.0/10.0-15 weight 22lbs
mt drag radials---P275/50R15 26 X 11.50R15 weight 31lbs
tires are only for the strip,looking for something thats going to hook hard and keep up the mph netting me the best 1/4 mile time.
im leaning towards hoosier qtp cause there way lighter than the mt drag radials,it seems i always hear a sponser saying his wheels have a big advantage cause there the lightest on the market,so shouldnt this be true in a tire also,IDK some on school me on tires,please.
should i go with
a quote from the man himself
"If you compare our drag wheels to theirs, ours are lightest...compare our new street designs to their street designs...ours are lighter...they don't offer a road race design that I'm aware of so I can't give you those comparisons.
Our wheels are also direct fit whereas they do not offer both front/rear direct fit wheels. If you're looking at our LS1 direct fit drag wheels compared to their street/strip wheels...there's no comparison regarding weight. Realistically though, its not really a fair comparison as its apples to oranges for their intended usage. For a weight comparison if you're curious, if you use our direct fit LS1 front/rear drag wheels it would be like you've lost about 64 converted static lbs from your car!"
Ive also heard rotational weight has the outcome of about 4x that of stationary weight.so a tire that weighs 10lbs lighter is like losing 40lbs from your car? 10x4=40 now combine that with 2 rear tires is like 80lbs?
tire
Seems to me you will want the lightest tire possible that will hook. The key is to accelerate faster that way you can mph to the end (sooner you accelerate in the 60', the more mph you have to carry the difference of the track). Seems Bias Ply fits the lightest. Don' t know how much more a DR weighs, but I hear they mph a little better.
but, i ain't the expert. Test and tune and let us know the results.
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
Radials are usually heavier than slicks, but remember a few things beyond the weight:
#1-they won't grow as the car gains speed (effectively changing your rear end gear ratio)
#2-less rolling resistance than a slick
FWIW: my Nova runs about .05 quicker on a 275/60/15 M/T drag radial versus a 28 x 10.5 x 15 ET Drag on the same wheels.
Derek
Derek
hoosier all the way either the qtp or the drag radials are amazing compared to the mt my family runs hoosier on all 4 race cars thats et's from 12.90 -9.50 for you i'd probably go with the drag radial they work with these cars
Derek
Derek
don't forget about the addition of the coolant by pass.
If you want Abe, we could go to the track and run on each others tires. I have 26/10.5/16 ET streets, not a slick but they are a bias ply tire. I've been wanting to try a stiffer sidewall tire to see if it would take the hit better so this would be good for both of us. Let me know.
resddd
I think buying used tires is like buying a used condom. Used tires will never hook like new ones. Not an apples to apples deal.
I have 275/60 mt drs and a set of 28x10.5 mt slicks and my car will hook better on the slicks. It takes a very well prepped track for my car to work on the drs. Now that is due to my setup not being ideal for drs.
Slicks are going to be more forgiving on track that are not prepped really well or if your chassis setup is not perfect.
The drs have a faster reaction time and do not grow making it nice to run tight tire clearance around the wheel well. With slicks you will want to allow at least 1" clearance around the tire.
Hoosier or Mickey's are both going to work well.
I think used tires are better cause there broken in,right?,Idk im no expert just trying to make my car a little faster.
I hope your right cause I bought my 255/50/16 dr used and they hook me all day long to 1.60-1.64',so with new ones i should hook better?mine aint bold probably 60% life left.
Hoosier 275/50/15 drag radials for sure. I love them and they are way lighter than the mickeys. I weighed mine when I got them and got 24 lbs each, not the 22 that hoosier advertises though.
