Drag Racing Tech
QA1 Guys come in
Old 12-05-2009, 06:18 PM
223HAWK's Avatar
Default QA1 Guys come in
Im wanting to get some QA1s for all four corners of my hawk. Im not happy with the way its transfering weight and traction. I want to know are they good for an all around shock spring set up. I plan on running the 300lbs up front and some pro kits on the back. I want to lower my car a bit and make it hook up a bit better. Iv been told these are great and I will love them and others tell me Ill hate them and the car will feel sloppy and not fun to drive. I have more of a street/show car than a race car but Im wantin to dip into the mid 11s on motor if its possiable in a full weight car with my set up..
Old 12-05-2009, 07:26 PM
BADD SS's Avatar
Well, my car is light, but I have QA1 single adjustable coil overs up front with 275 lb springs and I love them! Out back I have strange single adjustable coil overs as well, with 200 lb springs... To me, it feels great, and the front of my car is slammed, back is low but it has a rake to it. Hooks great, and looks good to me, rides great as well, and I do drive it on the street.
Old 12-05-2009, 08:08 PM
223HAWK's Avatar
How well do they do in corners? Im not ganna be hitting a 30MPH corner at 95 but would like to take them at 45 or 50 and feel safe..
Old 12-05-2009, 08:17 PM
rtr2001ss's Avatar
Shouldn't be anymore of a problem then what you have now. Got 12 ways all the way around with 300Lbs in the front, stock springs in back cut an inch. The front set you can make as high or low as you want. I want to get regular height rear springs cause my car doesn't look right to me.
Depending on how hard or soft you set the springs will determine the cornering ability.
Old 12-05-2009, 08:19 PM
James Montigny's Avatar
QA1s are drag shocks, that's it.
They do very well at the dragstrip, but they are not what I'd call a good handling shock.
You don't have to baby it on the street (unless you're on skinnies), but you can't go abuse
them the way you might an AGX or Strange shock.
I currently run 275# springs with QA1s up front / stock springs with QA1s out back.
I've run them in "race" setup (9 rear, 2 front), it's painful LOL
I usually set them around 5 or 6 on the street.
Old 12-05-2009, 08:40 PM
Mean87SS's Avatar
I have 275lb front springs and they do feel much looser then my stockers...
Old 12-06-2009, 07:16 AM
Race your car!
JL ws-6's Avatar
I'd start with 12 way's all around, and leave the stock springs on the car. That way the weight is supported properly... putting 275 lb springs on a car that's more then 3200 lbs, is a really bad idea. It's not enough spring to hold the car up for street driving IMO.
Just the shock change, and addition of a good rear swaybar, will make a world of difference.
Old 12-06-2009, 10:59 AM
223HAWK's Avatar
But If this is a car I enjoy cruzin around in on nice days and little track time..Will I like like them for driving on the street, will the car feel crappy and ruff?
Old 12-06-2009, 05:22 PM
nocooler's Avatar
The QA1's are adjustable - on 1 they are soft and on 12 they'll rattle your teeth out.
I normally run mine at 7 or 8 and they ride and handle great.
Old 12-07-2009, 06:28 AM
Race your car!
JL ws-6's Avatar
I ran mine on the street at 5 and they rode decent, 6 was spoty feeling, 7 was stiff. 4 they seemed to allow a little more weight transfer then you want.
1 they were just stupid, tried it for about a 1/2 mile LOL. 12 was the same, just too stiff to be enjoyable.
Old 12-07-2009, 10:34 AM
Internet Mechanic
BlackScreaminMachine's Avatar
I put on 12 rears, stock rear springs, and it has a Drag bar by UMI. Runs on 5 and drives great, you can feel it feed back, not annoying at all. I will soon have R Series fronts and then I can go make track runs.
Old 12-07-2009, 12:41 PM
LS1TECH Sponsor
Steve Burger's Avatar
For the $$ I would look at AFCO. The SA shocks are 199.00 Each and the DA are 299.00 Each. They are a better shock for not much more. You will be fine on the street with them.
Old 12-12-2009, 04:35 PM
NHRATA01's Avatar
FWIW I've been running the 12 ways on my car for about 5 years with stock springs. They're great at the strip over stock. They're not that great on the street. I set them to 6 all around, and the car is very bouncy but with limited travel. I feel like a ricer with cut springs sometimes. They will handle well if you set them stiffer - definitely not Koni's or anything but probably a hair better than stock.
Old 12-13-2009, 08:58 AM
Chris05ssTruck's Avatar
I have QA1's adj.'s on all 4 corners. With all being adj. you can adjust them to how you like them...i don't see a big deal. Made a world of difference in weight travel and hooking.
Old 12-13-2009, 11:13 AM
Sofls1's Avatar
I totally agree with this statement. I daily drive my car, have the 300lb springs on the front and its definitely loose. If your concerned about corners, I would use the stock springs with the QA1s. This would be your best bet option for getting the best of both worlds.
Old 12-13-2009, 12:01 PM
JD_AMG's Avatar
Stock spring rate is 292lbs/in, your spring rate is actually slightly higher, but you are still loose. This is because of the shock, not the spring. Its a drag shocks and made to transfer weight, it doesn't control the spring or car properly and therefore makes it feel loose, floaty, disconnected and will generally have you slamming on bumps.
"Best of both worlds" would be something like Konis, where you get BMW like handling and ride quality and still have a decent launch.
Old 12-13-2009, 05:38 PM
Moderator
thechef's Avatar
i run Qa1 12 ways on all 4 corners, and my car is a street car and i run the 300 or 325 spring up front i dont remember since its been so long, but the fronts ride fine set on 4 the rears i am not 100% happy with on the street, the car kinda rides like a lowered honda a little bouncy but i am NOT afraid to take a off ramp at a fast speed with them at all
now at the track they work awesome
Quick Reply: QA1 Guys come in
