Remote mounted waterpump - LS1TECH
Thread Tools Search this Thread
Old 12-17-2009, 10:28 PM   #1
Default Remote mounted waterpump
I am interested in using a remotely mounted pump and some fitting blocks but I haven't had any luck finding them or any info on how man GPMS the pump has to put out. Where can I get a radiator that has just and inlet and outlet, I want to do a filler neck in the hose and just get rid of the stock radiator with all its ports and hoses.
913MOTOR is offline   Reply With Quote
Old 12-18-2009, 06:42 AM   #2
LS1Tech Sponsor
MADMAN's Avatar
Give us a call. We carry Meziere pumps and also the block plates etc. I also have AFCO radiators built to suit your needs. 225-673-3533
MADMAN is offline   Reply With Quote
Old 12-19-2009, 04:47 PM   #3
ATwelveSec02Z28's Avatar
I did my own setup, probably woulda saved a few $'s if I just went with Madman or Burkhart
ATwelveSec02Z28 is offline   Reply With Quote
Old 12-20-2009, 11:14 PM   #4
I am more interested in an electric waterpump that is remote mounted. Like what s/c intercoolers use.
Old 12-20-2009, 11:30 PM   #5
pro382d's Avatar
i believe that is what is what he is showing, you can barely see the mezeire pump in the bottom left of the first pic and it is visable in the second pic also
pro382d is offline   Reply With Quote
Old 12-21-2009, 08:25 AM   #6
The pump Im running is a remote mount pump. Its actually a radiator mount - Call Madman he can get you set up with a custom Afco Radiator. Mine has 2 x -12AN ports for the inlets (and a 1/4" NPT Bung for the steam vents) and the meziere pump has an adapter that needs to be welded on for the outlet.
Old 12-21-2009, 08:34 AM   #7
tim99ws6's Avatar
I have a CSR remote mounted pump. We have ours mounted on a plate onto the front of the frame rail on the driver's side.
I bought the generic Griffin Radiator that all the FI guys use from Summit, then called and sent it to Griffin to have new end-tanks welded on with -an fittings welded onto it where i wanted them. I think the whole radiator setup cost me about $300, and the CSR pump was less than $200 off Ebay, haha.
tim99ws6 is offline   Reply With Quote
Old 12-21-2009, 11:18 AM   #8
LS1TECH Sponsor
Steve Burger's Avatar
Check our site. we have them mounted into a bumper support.
Steve Burger is online now   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
FS: New Meziere WP361 55GPM Remote Pump/Intercooler Pump t76coupe Parts Classifieds 2 09-01-2016 03:08 PM
Need radiator hoses for 70 Monte LS Swap 1975delta88 Conversions & Hybrids 2 04-20-2014 03:20 AM
Remote Electric Water Pump WITH Heater?? h_friesen Generation III External Engine 17 06-05-2012 03:20 AM
Afco / Meziere Remote Pump and radiator setup (1000+ HP) xssive Parts Classifieds 7 04-29-2012 07:06 PM
LS3 Steam Tube Question Carguyrob598 Generation IV External Engine 2 01-19-2012 12:19 AM
Tags
afco, burkhart, csr, engines, griffin, ls1tech, mount, pump, pumps, race, radiator, radiators, remote, running, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
