M/T 29.5x10.5W with Wolfe Offset LCA's?
For those of you running Wolfe offset LCA's and M/T's 29.5x10.5W tire, how much clearance do you have to the LCA?
I had Hoosier 10.5W's on the car which fit fine, but was wondering if the M/T would work since it is a bit wider.
Race your car!
It's gonna be tight. if you have the arms right against the inner most part of the stock lca mounting holes they will fit, but it's tight. Not alot of room for a thick diameter control arm.
I don't have a measurment/pic, but I have seen them on cars and they will fit, at least eth 28x10.5W size. The 29.5x10.5W, is that any wider?
