Drag Racing Tech
Need help - Removing some metal from the interior
Old 01-04-2010, 03:31 PM
LadyDriven's Avatar
Default Need help - Removing some metal from the interior
I'm in the middle of doing some weight reduction on the car, and I attempted removing a few spot welds over the weekend with a spot weld cutter. I managed to get the clam-shell looking things that hold the rear seats down out successfully, but when I tackled the metal that supports the rear passenger armrests, I had a hell of a time. Other than the spot welds, it seems to be "glued" in place somehow. I've never done this before, and was a little worried about damaging the car, so I've just left it for now. Once the spot welds are cut out, can I just pry it off with a small chisel/crowbar?
Thx,
Amanda
Old 01-04-2010, 04:29 PM
913MOTOR's Avatar
Mine had kinda rusted underneath the glue so they came off with a couple twist, but best bet is get a hair dryer thats real strong or a heat gun and a scraper.
Old 01-04-2010, 04:33 PM
LadyDriven's Avatar
That was going to be the next thing I tried, thanks!
Old 01-04-2010, 04:42 PM
IH8FORD's Avatar
In the body shop I use a propane torch and a putty knife for splitting seam sealer and glue.
Old 01-04-2010, 04:46 PM
LadyDriven's Avatar
Sweet, thanks.
Any tips for removing the spot welds? I broke 6 of my boyfriend's small drill bits trying to put the holes through the welds to line up the spot weld cutter
Old 01-04-2010, 04:48 PM
cbra-klla's Avatar
Originally Posted by LadyDriven
Sweet, thanks.
take your time and invest in some good drill bits....
Old 01-04-2010, 04:49 PM
LadyDriven's Avatar
I was taking time, and I'm pretty sure he has good drill bits. Or HAD good drill bits at least.
Old 01-04-2010, 05:07 PM
James Montigny's Avatar
JBWeld them back together and put them back when you found them.
Old 01-04-2010, 05:09 PM
LadyDriven's Avatar
That'd be a great idea, 'cept he was in the car tent beside me working on his own car, and could hear me swearing loudly everytime I snapped another one
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
I just used my grinder on top of them. I eventually knocked off enough of the metal on the bracket that I was able to pry it off. Then just smooth down what is left with the grinder. If you put a small hole in the floor it can always be tack-welded shut.
Old 01-04-2010, 06:17 PM
IH8FORD's Avatar
Sweet, thanks.
I always just drill all the way through with good drill bits and weld the holes back up. it saves time in the long run.
Old 01-04-2010, 06:19 PM
BAKED's Avatar
+1
Cutoff wheels and grinding discs are alot faster than tying to drill out all of the spot welds.
Old 01-04-2010, 08:00 PM
nickp's Avatar
i did mine last weekend. i just center punched all the spot welds then used a #3 center drill. luckily, i was able to do all of them with one bit. it took longer than i thought it would, but turned out pretty good.
Old 01-04-2010, 08:40 PM
InsaneAuto86's Avatar
Originally Posted by BAKED
+1
+2... I did the same
Old 01-04-2010, 09:02 PM
LadyDriven's Avatar
I don't know how to weld, hence the spot weld cutter. I don't mind having teeny little holes in my car, but I can't have huge spots where I've drilled through
Old 01-04-2010, 09:44 PM
Skinny's Avatar
Are you using a center punch to mark your spot before drilling? If not, get yourself a center punch and a hammer. That will help hold the bit centered where you want it without having to "steer" the drill, which is what usually leads to broken drill bits.
Old 01-04-2010, 10:49 PM
LadyDriven's Avatar
yup, I was using one, but I'm pretty little, maybe I wasn't hitting it hard enough to make enough if a dent.
Old 01-05-2010, 08:36 AM
You can use epoxy putty for the little holes if you dont want to weld them.
