Drag Racing Tech
Some ladder bar questions
Old 02-05-2010, 01:13 PM
w3s1c0a5t's Avatar
Default Some ladder bar questions
Im swapping to a 8.8 and a PG. Here's Why im wanting to swap
1) No longer have TA mounting points. The crossmembers for the tranny that have the mount for the TA are 250$. And the mounts on the Axles are pricey and difficult.
2) The autofab kit i plan on running Looks amazing as far as quality and running it with the front cross member and diagonal link is about 450$ total.
3) Saves the money on having to buy a sway bar.
4) I just want to be a little different.
Has anyone swapped a 4th gen to ladder bars that has pics?
Any other input would be nice on the swap. Looking for a lil direction before i order it all.
Old 02-05-2010, 03:13 PM
LS1Tech Sponsor
MADMAN's Avatar
The problem with ladder bars on these cars is that the bars are so long you have to cut into the rear seat foot well to get the clearance you need.
__________________
www.madmanandcoracing.com
225-343-9029
Old 02-06-2010, 12:13 PM
w3s1c0a5t's Avatar
When i talked to autofab about it they said i wouldnt have to cut into the floor pan?
Have you ever seen their kit? It looks like great quality to me.
I know your a pro when it comes to hooking up these cars so if i ask questions im not arguing just learning and trying to set my car up for me.
Old 02-06-2010, 02:40 PM
promod1955's Avatar
your going to have to cut out where your feet are, as well as the low area dirrectly below the seat.
Old 02-06-2010, 06:21 PM
w3s1c0a5t's Avatar
The ones im talking about mount to a cross member that goes under the DS and connects to the subframe connectors.
Old 02-06-2010, 10:58 PM
cncbird's Avatar
Yea but that crossmember goes about 3' in front of the axle centerline which is way under the rear seat.
Old 02-09-2010, 01:16 PM
w3s1c0a5t's Avatar
Does anyone have any pics? Are we really getting into hacking up the car?
I like this idea a lot better than what goes into fitting the torque arm on the 8.8 and PG
Old 02-10-2010, 03:07 PM
cambirdracing's Avatar
the c2005 ladder bars are very nice. I would see that you need to notch the floor to get them to fit. At least you do on a 1st and 2nd gen. I have them on both my 1st and wifes 2nd gen's.
http://competitionengineering.com/ca...?CatCode=11002
This is on my 68
Old 02-11-2010, 05:34 PM
w3s1c0a5t's Avatar
Talked with Josh at autofab. He said their shorter street style bars would fit without floor mods. Also that the only negative was it would hit the tire harder. Which with the 325's and a powerglide should help rather than hurt.
Any thoughts? Should be a good setup. I'd have about 600$ In it using their crossmember and diagonal link. Seems like a good deal considering what I'd spend on a good tq arm LCA sway bar and panhard bar. This and SA shocks on stock springs trimmed about a coil was the plan for the rear suspension.
Old 02-18-2010, 04:04 PM
w3s1c0a5t's Avatar
Bump still looking for more info.
