Drag Racing Tech
How much to cut off my rear
Old 02-07-2010, 09:49 AM
UrSmked's Avatar
Default How much to cut off my rear
I just bought some Weld Rodlites with 5.5" backspacing. Without dropping my 10 bolt thats in place now and setting the wheels under the car to take a measurement, I was wondering if someone could tell me how much to cut off my rear. I will be getting a 9 in very soon or an S60. It shouldn't change the measurement based on which rear I get right?
Old 02-07-2010, 09:56 AM
Top Fuel's Avatar
whats the width of the wheel?
Old 02-07-2010, 10:16 AM
second_2_none's Avatar
If the wheel is 10" wide then you will need to order your new rear end 2" on either side. No the measurement will not change based on which rear you buy, but they will narrow to any length you request when you order one.
correct me if I'm wrong anybody.
Old 02-07-2010, 12:55 PM
wlsmoku's Avatar
you are spot on - 2" each side with a 10"rim and 5.5" bs.
Old 02-07-2010, 02:24 PM
UrSmked's Avatar
Yes it is a 10 inch wheel, sorry for not including it but thanks for the info.
Old 02-07-2010, 04:37 PM
promod1955's Avatar
If you want the wheel sucked in a touch more, you can go 2.5" on each side. Youll have to cut the bump stop brackets off though so the rim/tire doesn't hit when the rear end is hanging.
Old 02-08-2010, 05:44 PM
kierstyn's Avatar
What he said. I think you would like the way it would sit at 2.5 per side.
Old 02-08-2010, 05:49 PM
xpndbl3's Avatar
that would be a stock thirdgen width at 2" narrowed per side. If you want it to look killer have it narrowed 2.5" to 2.75" per side and it'll tuck really nicely. I run a thirdgen width with 6.5" backspacing rims, so that would be like 3" narrowed per side.
Old 02-08-2010, 06:47 PM
UrSmked's Avatar
thanks for all the help guys
Old 02-09-2010, 01:20 AM
Zmg00camaross's Avatar
anyone have pics of the 2.5 narrow rear with the wheels.
