powerglide crossmeber ?
any one know what the diff is between the 93-97 and 98-02? i got a bmr crossmeber for a glide for my 93 and only 3 of the 4 bolt holes line up, not sure if i got a 98 and up one or just one thats bad......The worst part is i got ahead of myself and was setting up motor/mid plate.....i just hope theres no diff in the front/back on the crossmember where the mount goes
where it bolts up on the driver side is completely different between the LT1 and LS1 style cars. the passenger side is the same. so if you got 3 bolt holes that line up, odds are you have the correct crossmember just made a little off. if you had one for an LS1 car it wouldnt even be close.
