Drag Racing Tech
Summit 3way Drag Shocks
Old 02-11-2010, 12:56 AM
Matts94Z28's Avatar
Default Summit 3way Drag Shocks
Has anyone here shown any concrete gains w/ these shocks? It it to my understanding that they are just re-packaged Comp. Engineering pieces. I am looking to clean up my 60' this season on my otherwise stock suspension car. Over the last week I have added the shocks, re-location brackets, SFC's and removed my sway bar.
I am looking for people who have either shown gains or had issues with these shocks. It is to my understand that the Summit brand shocks are just Re-labeled Comp. Engineering pieces, so I sprung for them. I am not here to hear about how Strange, HAL, or QA1 are much better for the money, that is all I could find using the search.
Also, what are you guys setting these shocks at? I assume the "F" is 50/50, which is where I plan on setting them. Also, where would you guys recommend I set the stock LCA's in the re-location brackets?
Like I said, any real info would be great!
Old 02-11-2010, 06:50 AM
studderin's Avatar
there are not the CE there are doetsch shocks.
http://www.doetsch-shocks.com/
will say it right on the shock, they list the PN as only fitting up to 3rd gens, or LT1 Fcars but they fit are cars too. They just exstend a little longer, so the rear end will hang lower if you jack up the body. Ther settings are diffrent too, so don't use what the CE settings are. I called and got the setting, set then at 50/50 and with changes to a spoll at the same time gained almost a tenth and a half is the 60s. Went from 1.55-1.57s to 1.47-1.43, but my tru-trac was starting to act up.
Old 02-11-2010, 10:26 AM
Matts94Z28's Avatar
Good info. Thanks! Anyone else?
Old 02-11-2010, 11:46 AM
Skinny's Avatar
I got a pair of them sitting in the garage. Haven't had the time to install them yet. Just going to try the 3 settings on it and see how it does on my car. If it doesn't work for me, I'm only out $70, so it's not a huge loss.
Old 02-11-2010, 12:58 PM
studderin's Avatar
I posted up what the setting are after I called them. look them up, might be in my build thread?.
its not the setting everyone things they are (CE) the F,R,S or whatever. the "middle" isn't the 50/50 everyone thinks they are.
Old 02-11-2010, 03:53 PM
Skinny's Avatar
Thanks for the heads up studderin, I'll dig through your build thread before I install them.
Old 02-11-2010, 11:07 PM
Matts94Z28's Avatar
I found this:
Originally Posted by gonzo4886
I called summit and asked what the setting are their shocks
R 70/30
F 50/50
XF 40/60
I also looked on competition engineering website for their settings
R 50/50
F 40/60
XF 30/70
In this thread:
https://ls1tech.com/forums/drag-raci...-shocks-3.html
Old 02-18-2010, 10:46 PM
EATSGTS's Avatar
Anyone have a part number on these?
Old 02-18-2010, 10:52 PM
I_Need_Land's Avatar
summit g7700
Quick Reply: Summit 3way Drag Shocks
