steering wheel
steering wheel
looking at putting a different steering wheel in my 1995 camaro because i removed the air bags, was wondering what steering wheels you guys are using,what diameter,i have no power steering,tubular everything up front,3450lbs race weight with driver, im looking at http://www.jegs.com/i/Grant/470/1075/10002/-1 is the 13in diameter to small with no power steering? and what install kits work with the stock column. thanks
that should work. sometimes people have issues with the wheel rubbing the column so they stick washers in there to space it out enough to clear.
https://ls1tech.com/forums/drag-raci...eel-today.html
http://www.summitracing.com/parts/GRT-3196/?rtype=10
