Drag Racing Tech
BMR Alternator Bracket on 6.0L ?
Old 02-25-2010, 07:59 PM
daschra79's Avatar
Default BMR Alternator Bracket on 6.0L ?
I tried searching and couldn't find what I was looking. So hopefully someone can answer it for me.
I just bought a BMR Alternator relocation bracket for my 6.0L LQ4. I just went to mock it up on the block to drill and tap the hole like BMR says is needed for the 6.0L. My problem is that there aren't any existing bolt holes in the block that allow the top bracket to reach the tab that needs to be drilled and tapped. Also none of the supplied bolts fit in the existing holes.
I know I have seen a picture on here somewhere on how to mount this bracket on a 6.0L but I can't seem to find.
Old 02-25-2010, 08:31 PM
silverz28camaro's Avatar
I have an aluminum ls2 6.0 with this setup, I'll try to get pics tomorrow night of where mine is mounted, belt size, setup, etc.
Old 02-25-2010, 08:32 PM
Where are you at in st.louis? I'm further down 44 close to Eureka
Old 02-25-2010, 08:36 PM
daschra79's Avatar
That would be cool. Thanks
I am on the Illinois side in Belleville.
Old 02-26-2010, 09:51 AM
csjta2's Avatar
Is this the bracket?
Old 02-26-2010, 10:25 AM
daschra79's Avatar
That would be the one, Thanks man!! You still have to drill and tap that tab correct?
Old 02-26-2010, 06:06 PM
csjta2's Avatar
Yes on the Iron Block the pad is there, it's just not drilled/threaded
Old 02-27-2010, 04:48 PM
daschra79's Avatar
Do you happen to remember the size it needs to be? Thanks again.
Old 03-17-2010, 06:25 AM
Clean94Z's Avatar
Is that hole already in the head?
Old 03-17-2010, 08:45 AM
LTFOUR's Avatar
Looks like it utilizes the power steering bracket holes.
Old 03-17-2010, 03:36 PM
daschra79's Avatar
Yes the hole is already drilled and tapped in the head.
Old 03-17-2010, 04:28 PM
Reboot's Avatar
I was running the BMR bracket directly from the crank pulley to alternator on my LS7 block. I kept throwing or chewing up belts no matter how tight I had them on there. I got 1-4 passes per belt (gatorbacks). I recently went back to a stock mount and Katech tensioner and the problem was solved. Dunno why the belt wouldn't stay on as everything lined up perfectly.
Old 04-13-2010, 11:19 AM
LTFOUR's Avatar
They said this is designed to be used with an electric water pump.
Why run a belt around the stock water pump if there's no other accessories needing that belt?
Old 04-13-2010, 03:14 PM
LS1SpeedAddict's Avatar
yep that's a pic of my engine, thanks for saving me the time to post it. I drilled and tapped a hole in the block and used the bottom hole on the cylinder head.
Old 04-13-2010, 04:19 PM
red1999z28's Avatar
This isn't on a 6.0 Liter block but I have the same bracket on a stock LS1 block....figured the pictures might help some...
Quick Reply: BMR Alternator Bracket on 6.0L ?
