Drag Racing Tech
ABS/Air bag questions - street/strip car
Old 02-26-2010, 11:51 AM
nocooler's Avatar
Default ABS/Air bag questions - street/strip car
ABS - since going with different sized tires in the front/back when I grab the brakes after going through the traps - it feels like the left front and right rear brakes are doing all the work. It's fine on same sized tires - just with the skinny's and ET Streets on it.
If I pull the ABS fuse will this go away? I'd like to keep ABS for the street.
Air Bags - I've heard some horror stories about air bags deploying at the track. I figured I could pull the air bag fuse as well while I'm at it - will that work?
Old 02-26-2010, 12:22 PM
5.3LJimmy's Avatar
Yes if you pull the fuses it will disable both options.
