1/8th mile mph is weak compared to ET??
Here is the setup
6.0 370ci
PRC stage II LS6 heads 11:1 comp
236/242 .605/.613 108+2 degrees advance
Victor Jr. intake
4150 EFI Throttle body
Moser 9" 4.11 gears
275/60/15 MT drag radials
4L60E transmission
Yank SS 4000 stall converter
Full Spohn/BMR suspension
Hal R series shocks in front and back
weight with driver 3450/3500lb. range
Now i have not got to run this new setup in over a year but have always wondered why i never mph really good in the 1/8th mile. I'm starting to wonder if the cam is not right for the setup. My buddy mentioned something about another friend of ours cam profile was much different and maybe that was why our et and mph was down. It became really noticeable yesterday with the new 4 barrel 4150 throttle body setup because i and other could hear the motor completly change in the top of 2nd gear and all of 3rd gear then i really came alive and would run very well on the topend. I thought about maybe it wanted more gearing but if i went to a 4.30 or 4.56 it might hurt me when i start spraying it.
Yesterday's best pass at a local 1000ft. track
60ft. 1.45
330. 4.41
1/8. 6.95@95.50
1000ft. 9.13@113.01
6.0 370ci
Victor Jr. intake
Moser 9" 4.11 gears
4L60E transmission
60ft. 1.45
330. 4.41
1/8. 6.95@95.50
1000ft. 9.13@113.01
Any cam racing gurus care to share info? I'm thinking of raiseing the LSA some to get it to rev higher into the power band faster because im starting to think the lower LSA is not keeping up until the motor begins to get momentum on the other end of the track.
here is my time slip from my old set up 370 with patriot stage 3 heads ms3 cam 11-1 compression 28 degress of timming. 4l60e with a 3500 stall, fast 90 nick w. 90 t.b.
60ft.1.56
330.4.55
1/8th= 7.085mph 96.77
1000ft 9.2
1/4 =11.1 @119mph
60ft.1.56
330.4.55
1000ft 9.2
1/4 =11.1 @119mph
Here is the setup
6.0 370ci
Victor Jr. intake
Moser 9" 4.11 gears
4L60E transmission
60ft. 1.45
330. 4.41
1/8. 6.95@95.50
1000ft. 9.13@113.01
6.0 370ci
Victor Jr. intake
Moser 9" 4.11 gears
4L60E transmission
60ft. 1.45
330. 4.41
1/8. 6.95@95.50
1000ft. 9.13@113.01
least you ran a 6.9x on motor I barley got a 1.65 all motor .
Just don't give up on it...put the guitar down, I'm sure we can figure our **** out
I plan to do that and get all the little grimilins out of the suspension and get it dialed in so i can see what is really happening. Im just looking at other options on the cam profile because of the way the power curve was so noticeable on the high side of the runs i made.
Al
