What Kirkey pro street width to get? And 5 point harness length?
Hey guys, I'm about to order a set of kirkey seat but am unsure on what width to get. I was looking into the 17" wide, but after doing a search it seem they will be to wide for me. I'm 20 y/o 6' 190lbs with a 34" waist, so leaving a little room to grow might be a good idea, I doubt I'll ever be over 220 and 36" waist. What width do you guys recomend? The car will be driven on the street a fair amount so I don't want to be squeezed into them.
Also I'm going to need a pair of 5 point harnesses aswell, but am unsure of the length I'll need. They will be mounted to the rollbar cross bar. This is the set I was looking into.
http://www.summitracing.com/parts/SIM-29112BK/
Would these work? What would you guys recomend.
Thanks in advance guys.
Ryan
Ryan
The 17" is what you want. I'm 5-11 185 and they fit good. Had some Corbeaus that were narrow and never could get comf. in them. I bought some high density foam to add for padding. I cut it to fit under the snap on covers that Kirkey sells. The belts are adjustable, not sure of the length that I bought.
Man-Crush Warning
I'm using the racecraft brackets, I'm still trying to get my passenger one to fit in there, I'm having trouble as well. I think I'm going to have to do some slight grinding on the seat.
Mine was a tight fit on the pass. side. You can't move them back to the rear very far. I bought the race craft brackets and had to modify them to fit. It was a lot of work. I'm thinking about getting some other seats. Any ideas?
On the drivers side I used the stock non power tracks to mount them. The race craft brackets had me sitting to low and flat. Mignt do that on the pass side also.
