Drag Racing Tech
how fast can you go with a 6 point roll bar
Old 03-16-2010, 11:17 PM
lmt0705's Avatar
Default how fast can you go with a 6 point roll bar
just wondering what the fastest time I can go with a 6 point is? does it matter if i have swingouts?
Old 03-17-2010, 12:01 AM
LT1Formula007's Avatar
Check out the 2nd Sticky down from the top of the page.... In this section!
There is all the NHRA requirements for safety equipment.
But to answer your question, Here is what it says...
10.99 1/4-mile (6.99 1/8-mile) or quicker:
-5-point roll bar is still okay to 10.00 1/4-mile (6.40 1/8-mile) in hardtop / t-top with un-altered floors, firewall and frame rails (wheel tubs are okay). If the floor and/or firewall has been modified, then a full roll cage is required beginning at a 10.99 e.t. or any vehicle running 135 mph or faster (regardless of e.t.). The roll cage must be constructed of a minimum o.d. mild steel or chrome moly tubing (moly can be a smaller o.d and is lighter but more expensive), see diagram below for specs. Roll cage must be padded anywhere the driver's helmet may contact it while in the driving position, see diagram below for specs.
-Convertibles require full roll cage at 10.99 and quicker.
Hope that helps.... (So 5/6 point will be good to 10.00 or 135 mph MAX, unless it's a convertable then you need a full cage at 10.99 and quicker!)
Old 03-17-2010, 06:33 AM
Race your car!
JL ws-6's Avatar
10.0, soon as you go 9.99 or over 135 you need the 8.50 certn, lic, etc.etc.
Old 03-17-2010, 08:26 AM
94Z28rag's Avatar
Sucks to be me
Old 03-17-2010, 09:28 AM
9-Second Club
Ed Wright's Avatar
He asked about swing out side bars, mine is certified to 8.50 with swing out side bars.
Old 03-17-2010, 09:56 AM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
9.99 in the 1/4 mile & 6.39 in the 1/8th mile you will need 10 pt and a lic.
Coach
Old 03-17-2010, 10:00 AM
9-Second Club
Ed Wright's Avatar
Coach, it's 10.0. Go 9.99 and you have to have the cage certified, have a license, and a multi layer jacket & pants. Ask me how I know. <G>
Old 03-17-2010, 11:06 AM
lmt0705's Avatar
wow lots of different answers, sounds like I should just do the 10 pt with swingouts
Old 03-17-2010, 02:16 PM
9-Second Club
Ed Wright's Avatar
I run NHRA almost every weekend through the summer, at tracks all over the southwest. I have a six mounting points, but a bar goes around the top of the cabin, and the front tubes go down through the dash, just behind the windshield. Swing outs on both sides. Nothing through the firewall. CM, not mild steel. All tig welded. Certified to 8.50. A 7.50 cert ("10 point"), I'm pretty sure, doesn't allow swing out side bars, as there is an X across the door openings.
Old 03-17-2010, 03:42 PM
That is what I was trying to say Ed. I hope to join you in needing the cage certified. Hoping to hit very high 9's this weekend.
Coach
Old 03-17-2010, 03:52 PM
9-Second Club
Ed Wright's Avatar
Hope ya make it!!
Quick Reply: how fast can you go with a 6 point roll bar
