Drag Racing Tech
Strange drag brakes - brake lines?
Old 03-20-2010, 12:19 PM
99TransAmLS16Spd's Avatar
Default Strange drag brakes - brake lines?
Just finished up on the MWC 9" install w/ the rear strange drag brakes. What are you guys doing as far as adapting the brake lines to the caliper? I have the SJM braided hose, but the caliper uses an AN fitting(from the looks of it), not the factory type thru bolt.
Thank you
Old 03-20-2010, 12:55 PM
xpndbl3's Avatar
an to brake line adapter fitting
Old 03-20-2010, 03:54 PM
02Z28's Avatar
Same here.
Old 03-21-2010, 08:43 AM
Nabdrill's Avatar
x3....^^
Old 03-21-2010, 03:34 PM
Can I find this adapter at local auto stores or will I need to order it from summit? Thanks
Old 03-21-2010, 06:38 PM
Zmg00camaross's Avatar
I would like to know this also,
Old 03-22-2010, 11:08 AM
Reboot's Avatar
I bought complete setup from SJM and it came with the an to brake line adapter fittings. Not sure if they were sold seperately since I asked them for everything needed to install.
Call SJM and they will hook you up.
Old 03-22-2010, 03:08 PM
LS1TECH Sponsor
Steve Burger's Avatar
Give us a call and we can get you braided lines.
Old 03-22-2010, 07:20 PM
burkhart what would be a price on those.
Old 03-22-2010, 08:12 PM
LS1 SPEED's Avatar
We always use the SJM lines with Strange brakes and they are a direct bolt-on.
Old 03-22-2010, 10:26 PM
found it on the sjm website, looks like 69 bucks for the rear lines.
Old 03-23-2010, 10:26 AM
LS1TECH Sponsor
69.00 per set for front or rear. They are a direct fit.
Old 03-23-2010, 11:26 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
I have all the lines, adapters, and clips in stock for the setup to go from the strange brakes to your hard lines on the housing. kit is 40.00... call me and i can ship it out same day.
Quick Reply: Strange drag brakes - brake lines?
