Oil Question
Oil Question
Not going to turn this into a "what oil should I use?" Thread.
But, my car is going to race only now, and I got to thinking about how often I should be changing the oil?
I know some guys do it after every T'N'T, but right now I run Mobil 1 and that'll add up quick.
Do I keep the "expensive" stuff, and change less often? Or do I run just conventional and change after every track night or two?
What do you guys do? I'm not doing anything crazy performance wise
6 & 8 Second Club
I started off with Pennzoil -50 for years. I changed every time out.
It finally hit me throwing away all that spotless oil how stupid it is.
I started going to 10-15-20 pass' and then changing.
Now I'm using 100% syn Moble one, at 1200 HP I change every 25 pass'
It's still spotless, and with 12 qt's in the tank it's not getting worn out.
For a 800 HP car and 100% syn I change every 50 pass'
Good luck,
Good luck,
Race your car!
Depends, nitrous tends to get the oil dirty a little qucker.
If you want to be safe, run it 10 passes, then have an oil analysis done. If they are telling you it's 75% good, next oil run it for 20 passes, see what it says, I'd do this until they're telling you it's at abotu 40 to 30% of it's life and change it.
With nitrous, I'd guess that will be about 35 to 40 runs with stock oil capacity.
6 & 8 Second Club
Volume makes a difference. My 800 HP bracket car holds 10 qt's.
50 pass' might be a lot on on a 5-6 qt system??
Does anyone know of a local testing center in the RT 66 area.
That would be an interesting test to have done.
All information is good information in my book.
JL, thanks for the suggestion!!
6 & 8 Second Club
I'm doing it because I'm cheap. If it is says 25 is too long, I'm hurting my stuff.
If it says 25 is still 90%, I'm pissing away money. I never even thought of having it tested.
I emailed them, and the basic test, for $22.50 will give you the oil life.
Of course, they have other tests you can run, but I don't have a need for that.
Enjoy guys!
Enjoy guys!
