LS Motor plate & Mid plate problem
1) When running front plates with ls motors what are you guys doing with water pump pulley moved out thickness of plate? Out to far for crank pulley. 2) Mid plate & Ultrabell hit upper 4 bolts on rear main housing. Could change hex head bolts to round head cap screws for problem 2, but don't want to have to use electric drive for water pump. Can pulley be changed? Thanks, mike
Race your car!
Most people, once they put the motor plate on are already on an elec water pump.. I'm sure there's a way to get it to work. I'd guess this is a madman question, I'm sure he's done it already.
The rear sitation, I'd swap to a cap hex head bolt like you're saying... not sure what else can be done there.
Never even considered milling the pump. Thanks 1_bad_ss I think I'll try that. The rear I'll try different bolts, just can't bring myself to grind on my Ultrabell (yet). Thanks MADMAN & JL ws-6 I appreciate the help.
Just did this
ALl of my front assembly mounted to the heads. The only issue was the tensioner which mounted to the water pump. I milled a 1/4" from the back of tensioner housing. Worked out well.
