Drag Racing Tech
Mounting 2 1/16 gauges in radio delete panel
Old 04-06-2010, 11:58 PM
sidewayz28's Avatar
Default Mounting 2 1/16 gauges in radio delete panel
im posting this here because i figured only you guys delete your radios. I've never done this before so any advice would be appreciated. what should i use to mount my 2 1/16 gauges into a plastic ABS radio delete panel? theres gotta be some kind of mount? Thanks in advance.
Old 04-07-2010, 07:33 AM
BassProCamaro97's Avatar
I made my radio delete panel out of small gauge aluminum. I can't remeber exactly what gauge it was but it was not very thick at all. I prefer to work with ALuminum over ABS plastic. There are some pictures in the thread in my sig.
As far as mounting to the plastic, you cut a hole through the plastic that fits the 2 1/16 and the rest of the parts should be supplied with the gauge. The come with a large sleeve that holds the gauge it's self in place with two bolts after you slide it through the hole you just cut. It's pretty simple. You'll see exactly what I mean when you order your gauge(s).
~Jim~
Old 04-07-2010, 10:32 AM
sidewayz28's Avatar
ah right on man thanks for the info. would those same gauge mounts be used in an a-pillar gauge pod? thats where my gauges are mounted at the the moment.
Old 04-07-2010, 11:54 AM
Most likley. Here's a picture that shows what the gauge looks like when it comes through the hole. From there the sleeve uses the plastic as a pinch point to hold both the gauge and sleeve in place using the two bolts. It's really simple.
~Jim~
Old 04-07-2010, 01:22 PM
sidewayz28's Avatar
just ordered these guys... should do the trick
http://www.summitracing.com/parts/ATM-2230/
Old 04-07-2010, 03:27 PM
That is exactly what I was talking about. Those are the sleeves I was refering to.
They came with my gauges.
~Jim~
