Drag Racing Tech
Anyone launch at idle with a loose converter?
Old 04-18-2010, 02:59 PM
omcar's Avatar
Default Anyone launch at idle with a loose converter?
Heard that this works pretty well..right now I launch at 1800 but I know it fluctuates ..at idle no fluctuation.
omcar is offline
Old 04-18-2010, 03:47 PM
02 BLK WS6's Avatar
My car seems to 60' better when I footbrake it.
02 BLK WS6 is offline
Old 04-18-2010, 04:07 PM
Dan
Dan's Avatar
I launch at idle
Dan is offline
Old 04-19-2010, 06:50 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
The converter should flash higher if you launch from idle, you'll have to see how the chassis reacts to it. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Bob@BruteSpeed is online now
Old 04-19-2010, 07:53 AM
Race your car!
JL ws-6's Avatar
When I was running my car n/a I used to leave at about 1100, just enough so that the car was up in the rpm's enough so it would hit really hard. The venturi effect of the t/b just being cracked I think helped it.
I went the same speed doing that with radials as I did leaving @ WOT off the brake with slicks... so I can't say it was better or worse, but it did work
JL ws-6 is offline
Old 04-19-2010, 08:31 AM
Internet Mechanic
BlackScreaminMachine's Avatar
But at the same time, we saw some of the short comings of what radials and I wonder on a Nitrous car, with more weight out and suspension biased to making a Radial "work". Would the T brake be a benefit or still a Liability. I think it can work but there is no example of a car running today that I can recall. (I just have not done a ton of research). I am sure there is on a site like Y. Bullet.
BlackScreaminMachine is offline
Old 04-19-2010, 09:33 AM
tee-boy's Avatar
loose converters are a bore and a waste of time and money.
tee-boy is offline
Old 04-19-2010, 09:37 AM
tee-boy's Avatar
life is too short to spend resources on loose converters.
tee-boy is offline
Old 04-19-2010, 09:42 AM
Race your car!
JL ws-6's Avatar
I won't agree with that, n/a cars need a 6000+ converter to work.
BS, I think most of the radial guys limit the leave rpm with a step, I probably could have used the tbrake with them if I had a 2 step in the car too, just had to get that set to the rpm they would hold and go from there... I never went down that road though, I used to just plant the right foot and let go of the button, which didn't work, but footbraking did.
Worst part, was it went the same speed with slicks off the brake as it did foorbraking it, just tells me that either can work, just ALOT harder to get the reaction times on a protree down with the footbrake.
JL ws-6 is offline
Old 04-19-2010, 11:44 AM
Internet Mechanic
100% agreement on that.
Old 04-19-2010, 12:47 PM
tee-boy's Avatar
it's hard to get the reaction times down with a loose converter.
tee-boy is offline
Old 04-19-2010, 12:48 PM
Race your car!
JL ws-6's Avatar
Partially true, off a 2 step/transbrake the reaction time won't be that bad, footbrake and yes it gets alot harder.
JL ws-6 is offline
Old 04-19-2010, 12:49 PM
tee-boy's Avatar
it can be irritating when you ask a fella to build you a bracket converter and you get a street converter built for a 10 bolt.
tee-boy is offline
Old 04-19-2010, 12:51 PM
Race your car!
JL ws-6's Avatar
I can see that... ATI treemaster ftw.
JL ws-6 is offline
Old 04-19-2010, 03:40 PM
Dan
Dan's Avatar
Why is that?
Dan is offline
Old 04-19-2010, 03:53 PM
tee-boy's Avatar
Default dfdfd
Originally Posted by Dan
Why is that?
I'm not a ME. Go get your textbook out. Maybe you need to partially differentiate alpha, theta, and beta with respect to omega.
tee-boy is offline
Old 04-19-2010, 03:56 PM
Dan
Dan's Avatar
Guess we have a ***** in this thread..Maybe answer the question if you know so much.
Dan is offline
Old 04-19-2010, 04:07 PM
tee-boy's Avatar
Default dfddfd
I know my limitations, son.... I think that's obvious. hope you didn't get your feelings hurt.
tee-boy is offline
Old 04-19-2010, 06:15 PM
tektrans's Avatar
JL, I disagree with that on so many levels.
A solid roller spinning to 10k maybe, but not all N/A cars, certainly not mine, or any hydraulic roller for that matter can I see getting benefit from a 6k converter in a 1/4 mile.
An I'll add even solid roller N/A cars, one's without a dry sump set up and spinning under 8k would not need and will lose performance with such a high stall.
tektrans is offline
Old 04-19-2010, 06:19 PM
tektrans's Avatar
I've left at idle many times, mostly if the track is suspect that day but my best times came from bringing the rpms up a bit, like around 3k-my converter stalls around 4400.
I personally have never had any success leaving off the transbrake with radials but I'm sure it can be done with a 2 step and/or a suspension that's perfectly dialed in.
tektrans is offline
Quick Reply: Anyone launch at idle with a loose converter?
