Drag Racing Tech
Airbag modual on console removal??
Old 04-26-2010, 10:57 AM
AChotrod's Avatar
Default Airbag modual on console removal??
So just disconnect the battery then unplug it?? Tried searching and didnt get any real clear answer. Then hoe do you get out the PS bag?
Old 04-26-2010, 11:47 AM
5.3LJimmy's Avatar
You could disconnect the battery if you like, but pulling the fuse would be just as safe. You need to remove the dash to get the passenger's side bag out. There are a couple write ups floating around here somewhere for A/c removal that should help you with removing the airbag.
Old 04-26-2010, 11:51 AM
AChotrod's Avatar
I have the car empty and the batt is already disconnected. So if I just snip the wires the air bag isnt gonna go boom when put the battery in or something? Them things are scary!!!
Old 04-26-2010, 12:34 PM
AChotrod's Avatar
This is the stupid thing and about the last thing I need to pull
Old 04-26-2010, 01:09 PM
airfix's Avatar
I removed mine when I had the dash completley out. I have read that some people have gotten it out with the dash partially un bolted. you'll be fine the airbags wont go off, if your still woried disconnect the airbag (conector right at the airbag) then do what ever cutting you wanna do.
Old 04-26-2010, 01:15 PM
AChotrod's Avatar
Cool I just take it out then. Trying to offset the roll bars weight as much as possible
Old 04-26-2010, 07:50 PM
airfix's Avatar
Ya I know the feeling, its pretty heavy eh. I've deleted as much stuff as I can without cutting pieces off the car.
Old 04-26-2010, 07:52 PM
AChotrod's Avatar
its gotta be 60-70lbs so ***** gotta go! lol
