Drag Racing Tech
Do most of you race your front QA1s at zero?
Old 04-27-2010, 01:10 PM
omcar's Avatar
Default Do most of you race your front QA1s at zero?
Going to run them for the first time this weekend. I hear zero setting provides maximum weight transfer..any down side?
Old 04-27-2010, 01:27 PM
tektrans's Avatar
Putting it on the bumper is a downside.
How much power you making?
Old 04-27-2010, 01:40 PM
Internet Mechanic
BlackScreaminMachine's Avatar
I just got around to installing my R series Fronts and I already have 10 QA1's in the rear. Street set up is 5's all around.
When it goes to the track JL will be helping me set it up. With the M6 Trans I can definitly tell you the rears will be high, maybe 7 or 8. I don't know if they will need staggering but suspect it might. Fronts will be loose but I do not expect them to be Zero.
My issue on stock shocks was too good of weight xfer and not enough controlling of the body on the hit.
Now I can keep the rear stiffer and let the tire do the work.
Keeping the nose up is a key factor and thats why I went with the R series given my "Racing" Budget and Zero on the fronts wont work.
Old 04-27-2010, 01:49 PM
03 BUSA's Avatar
I run zero or 1 every time.
Old 04-27-2010, 03:35 PM
omcar's Avatar
Thanks guys..the car's set-up is in my sig.
Rears are at 5 and I will go with 1 up front to start with.
Old 04-28-2010, 05:54 AM
3rdgen92maro's Avatar
I had the best luck with my QA1s set at 2.
Old 04-28-2010, 05:59 AM
BES Stroked Nova's Avatar
lowest I been was 2. going to try 1 or 0 next time out with the new gears...
Old 04-28-2010, 07:36 AM
Fireball's Avatar
I run mine at full tight...but make a considerable amount of power
Old 04-28-2010, 08:45 AM
StreetSilverado's Avatar
You can damage the shock setting at 0 if it keeps bottoming out, ask me how I know. Really need to run at least 1 click. I usually run 2 and 1.
Old 04-28-2010, 09:56 AM
Reboot's Avatar
I was running QA1 R's at 2 and was cutting 1.4 and high 1.3 60's. We just recently went to 5 in front and it dropped to low 1.3's. I gave them one more click to 6 and let one of our Mods Cameron "camscam02" drive my car last time out. His 60's were 1.31, 1.29, and 1.30. We're thinking we can prolly go a little tighter on the front the next time out.
Old 04-28-2010, 10:37 AM
NHRATA01's Avatar
I had heard the same, so I usually run them at 1 or 2.
Old 04-28-2010, 01:16 PM
Internet Mechanic
The main point that I think everyone is trying to stab at is....
1) Every set up is different, down to the power level, raceweight, drive train, and so on and so forth
2) Trial and Error will be a key factor in determining what works for your car. Most can "ball park" you but in the end what works for 9 out of 10 cars may not always work for you.
Old 04-28-2010, 09:16 PM
1_bad_ss's Avatar
I always ran mine on 3
Old 04-30-2010, 12:39 AM
BlackWS666's Avatar
run mine on zero. But will be experimenting with tighter setting next time at the track on the bottle. But zero N/A has always been a big sucess for my car.
Old 05-03-2010, 11:42 AM
Packy's Avatar
I run mine on 3-4 usually.
Old 05-03-2010, 11:57 AM
dlove's Avatar
this.
Old 05-03-2010, 01:26 PM
omcar's Avatar
Well I ran it this weekend at 1 front and 5 rear.
My 60 foots were..1.64, 1.64, 1.64 for my first 3runs on a hot slow day.
I think I'll keep the set-up.
Old 05-04-2010, 01:53 AM
9sec93's Avatar
the more power you make the tighter you will set the front shocks. a friends car runs full stiff up front and cuts high 1.1x 60's or low 1.2x on the back tires.
Old 05-04-2010, 08:41 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
01 nbm formula A4 ramair hardtop. Stock motor. Built trans/3,600 Vigilante. Built rear/3.73s/Auburn Pro/Mosers. QA1s ++
12.02 @112, 7.60 1/8th, 1.57 60'...original owner:
I'd start off with 1/1 in front, and 6/6 in back. If the car works, I'd try to stiffen up the rears to 7/7. I've found over the years in Chicago that at GLD and Byron I'd usually end up at 1/1 on fronts and anywhere from 5/5 to 7/7 on the rears. You didn't mention what tires you are running and they factor in too. Change one thing per pass.
Old 05-04-2010, 05:02 PM
omcar's Avatar
Thanks for the tips..I run the M/T drag radials at 19lbs.
I have all the susp. stuff.
