Drag Racing Tech
Wiring ID
Old 04-30-2010, 11:46 PM
Broke EF's Avatar
Default Wiring ID
OK guys, what are these connectors, and can they disappear?
Thanks,
Sean
Old 05-01-2010, 02:23 PM
sweetbmxrider's Avatar
what year is the car? could you type out each connector and what wire goes to what cavity? i believe they are connectors 100, 101, and 105 but its tough to tell. thanks
Old 05-01-2010, 07:02 PM
Broke EF's Avatar
its a 98 TA, they are on the passenger wheel well. They all come forward then past the radiator and then tie into the main harness.
Sean
RENE'S RAGE's Avatar
Some wires can some cannot. You need to find a wiring diagram or trace out each individual wire. Some of the wires are 12v hots (PINK) coming from your fuse box to power your PCM, ing., fuel inj., ect. I think one is your starter wire.
But some can be done away with, but not many.
Old 05-01-2010, 10:20 PM
SScam68's Avatar
depends if you're going to completely rewire the car.
the purple wire is your starter wire.
fan relays, IGN wires, some sensors run through those connectors
