Drag Racing Tech
Radiator and cooling fans? stock vs aftermarket with 440ci
Old 05-05-2010, 02:06 PM
SlickVert's Avatar
Default Radiator and cooling fans? stock vs aftermarket with 440ci
I have a 440ci high compression motor that I will street/strip drive in south Florida and want to keep the cooling temp around 175 to 180. I have a Meziere Race Electric Water and looking for some advise on radiator and cooling fans options.
I am planning on getting a double core radiator, not sure witch one. I will build a new supports and install the fan straight vertical. What do you recommend?
Will I be better off with replacing the fans with an aftermarket like SPAL?
Should I go with a single large or double fan set-up?
Can I wire a aftermarket one into the stock fan wiring harness and still use the low and high speed?
What are you using and how is it working for you?
Bob
Old 05-05-2010, 03:15 PM
venom99's Avatar
im doing the same as you and will be running a spal fan a single since thats all we will need to keep the temps down also you do not need a large fan i would say a 16inch fan should be bout right and you can use the stock wiring on the fans for the new fan
Old 05-12-2010, 09:49 AM
SlickVert's Avatar
What radiator are you running?
Have you actual tried it with a single fan and what temp does it run at?
Anyone else have experience with this?
Old 05-12-2010, 01:44 PM
7 Second Club
Phil99vette's Avatar
My old radiator was perfect, 22 x 19, double pass with a 55gpm water pump. Single 1600cfm fan will keep it cool in the hot summer months.
Old 05-12-2010, 02:42 PM
venom99's Avatar
hear is the radiator i am using
http://www.summitracing.com/parts/GR...5&autoview=sku
and im using a 16 inch jegs fan that flows 2200 cfm it does the job
Old 05-12-2010, 02:49 PM
SlickVert's Avatar
Phil, great and thanks for the info
Bob
Old 05-12-2010, 02:54 PM
SlickVert's Avatar
Thanks
Old 05-12-2010, 02:57 PM
venom99's Avatar
you will need to buy a 1/8 or 1/4 aluminum bung to weld on to the radiator for your coolent air tube for the heads also
Old 05-12-2010, 03:55 PM
SlickVert's Avatar
Great thanks
Old 05-12-2010, 05:12 PM
fuel's Avatar
i just bought that same radiator
Old 05-12-2010, 08:43 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
Well I'm not sure what to say.lol We ran the 445ci, but it was only 11.8:1 and we ran the stock radiator, fans and OEM PCM. The stayed in the 175-180* range here in Texas with the 160* thermostat. Even after a hard 1/4 mile run she was only running 215-220*.
I am not sure what a high compression race motor would require. We may have been right on the edge of our cooling capacity, but we never lost control of the cooling temp.
Old 05-13-2010, 03:25 AM
HuMi's Avatar
Definitely on the ragged edge with it climbing like that at the end of the run.
We use the race griffin on a 700hp 408 with the stock fans, and condensor in front of it. I made my own radiator cover from sheet metal and ran the air tube in the stock battery location under the car. AC still intact and all. On spray it will see over 1000hp with the 4l80 in it.
Old 05-13-2010, 03:32 AM
suicidal racing's Avatar
i did also..im having -16 bungs welded to my lt1 water pump and the outlets on rad..for my steam pipes,im going right into the top right hole that is in the pump that was org for the heating return line..that will be -6
Old 05-13-2010, 08:43 AM
SlickVert's Avatar
Great idea, maybe I will just treat a pipe fitting into the water pump.
Bob
Old 05-13-2010, 10:24 AM
im not sure how the ls1 are but i know it will work forsure on the lt1 engines..
i just didnt feel like paying some one extra to weld another bung to the rad and then having to run an extra foot and a half or so to the rad.
im going to come off the steam hole in the rear of my heads with a 90 for the drivers side and then a T fitting out the rear of the pass side and then 1 line into the pump..that way if i have to pull the heads and stuff it just a matter of unbolting the 2 a/n's on the T an im good..
i believe with ls1 there at the front of the engines right..i would just run a T fitting in the dead middle of the heads and then from there go into the old water pump hole and stuff.
Old 05-20-2010, 06:26 AM
SlickVert's Avatar
What do you all think about the stock Fans if installed on a better radiator.
Bob
Old 05-20-2010, 08:07 AM
tektrans's Avatar
My 441 13:1 (LS7 aluminum block) motor was fine on the street with the stock radiator and fans.
I had the stock mechanical water pump-which is very important for a street driven vehicle IMO.
I personally think driving around with a high compression motor with an electric water pump is a mistake.
You being in Florida makes the water pump even more important. I'd seriously look into the Evans pump or the new PRW Industries water pump.
Old 05-20-2010, 10:19 PM
1cdub's Avatar
I drive mine alot on the streets and for long distances ~150 miles to MOKAN dragway. I've had zero issues with my mezeire drag pump, afco double pass radiator and dual 12" staggered fans. FWIW, I couldn't go 20 miles on the highway with the stock radiator.....NO WAY.
Old 05-21-2010, 06:22 AM
SlickVert's Avatar
Good info, thanks
Bob
Old 06-02-2010, 02:28 PM
SlickVert's Avatar
I order a dual pass double 1.5" row with 16" Spal fan.
What do you recommend for the wiring to run the fan?
Can I just connect one of the stock fan wire harness to the Spal fan or do I need to run a relay off the stock harness?
What do you think?
Bob
Quick Reply: Radiator and cooling fans? stock vs aftermarket with 440ci
