Another Leaking Linelock
i have a hurst roll control line lock with thunder racing install kit and it's leaking like crazy. the two plugs are leaking so i'm going to put a little thread sealer on those. but the fitting that goes into the side of the linelock is leaking between the line and fitting. like squirting out when i press the pedal. so what do i do about this?? is there supposed to be an adaptor or something that goes in there then i screw the line and fitting into that or what?
it is newly installed. thunder racing figured it out for me though. turns out i was missing a fitting that goes into the line lock. they're sending it to me now so it's all good.... hopefully
