Drag Racing Tech
Need Help Figuring Out (under) Dash Connector
Old 05-05-2010, 06:59 PM
Mikey 97Z M6's Avatar
Default Need Help Figuring Out (under) Dash Connector
I had my entire dash out of the car this winter for the rollcage install and I got it all put back together except for this one connector on the driver side. It's heavy gauge wire, light yellow, and brown with a blue connector. See pic below. Everything seems to work except the starter switch. I looked up the colors on a wiring schematic and it appears to be starter related (light yellow/brown). I've spent the last hour under the dash trying to find where it goes with no luck.... Anyone know where this little bugger plugs into? Looks like it should go to the steering column but I can't seem to find it...? It must be "cloaked"... lol....
Chassis is a 1997.
Mike
Old 05-05-2010, 07:14 PM
csjta2's Avatar
Clutch switch? On pedal
Old 05-05-2010, 08:27 PM
BINGO!! I owe you a beer lol...
It was the safety switch at the bottom of the clutch throw. I didn't see it because it plugged in from the outside of the switch where you can't see it.
Thanks man!! Just started up the fresh 370 for the first time.
Mike
Old 05-05-2010, 09:33 PM
csjta2's Avatar
Good deal!
Just starting my LS2 build, so hopefully soon it will run again!!
