Drag Racing Tech
Whats the fastest all ls1-ls6 setup?
Old 01-10-2004, 12:23 AM
Worm Boy's Avatar
Default Whats the fastest all ls1-ls6 setup?
I am just curious what is the fastest all ls1-ls6 setup out there, no c5r. Is it eastides car at 8.9?
Old 01-10-2004, 12:08 PM
Worm Boy's Avatar
Anyone know??
Old 01-10-2004, 01:08 PM
CHRISPY's Avatar
I think Eastside had a C5R block? Not positive though.
ARE went 8.92 I think at 155 with ported LS1 heads (not LS6) and re-sleeved LS1 block.
Old 01-10-2004, 01:27 PM
66ImpalaLT1's Avatar
I think Eastside has an iron block.
Old 01-10-2004, 02:04 PM
CHRISPY's Avatar
they had a C5R I think when they ran their first 8 second pass. I am sure someone from there will clarify though
Old 01-10-2004, 02:22 PM
JS
JS's Avatar
C5R block doesnt add any real HP at these levels.
Now the C5R heads would for sure...
But neither ARE or ESP had C5R heads.....
Old 01-10-2004, 02:37 PM
CHRISPY's Avatar
But his question was though:
Old 01-10-2004, 05:21 PM
Worm Boy's Avatar
Yes, thanks chris. I think eastside did have a c5r block. Any idea what ARE's race weight was with the ALL ls1 setup??
Old 01-10-2004, 06:32 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,088 Likes on 716 Posts
Eastside went 8.9 with a C5R block, and later went 9's with a iron block I heard.
Slomaro you including resleeved stuff I'm not clear on whether you mean stock cubes?
If that's the case then I think ARE went 8.9's and Cartek went 9.21 with too much converter.
Old 01-10-2004, 07:41 PM
OSR 1's Avatar
8.93 at 152 with C5R block with ls1 heads
9.00 at 155 1 and only pass with iron block Ls1 heads and Gen 7 DFI (30 over with 4 inch crank)
Old 01-11-2004, 12:37 AM
Worm Boy's Avatar
psj, no not stock cubes. Thanks OSR 1, by any chance you know what yalls race weight was??
Old 01-11-2004, 08:56 AM
7 Second Club
10.5 Dave's Avatar
Location: Grove City Ohio/Port Washington L.I sometimes
ARE went 8.92 with a resleeved LS1 block and either LS1 or LS6 heads in 2002.This record should be falling real soon.I know of 2 cars in Ohio that are capable of bettering that number.This Spring is going to be fun.
Old 01-11-2004, 10:21 AM
CHRISPY's Avatar
AREs weight on that 8.9 pass was 3300 pounds I believe.
There class min was 3200 but they couldnt reach it at that point and still have everything required for the class in the car.
They switched to a lighter hood afterwards and I think that got them (With some other minor stuff) around 3250 pounds)
Old 01-11-2004, 10:59 AM
OSR 1's Avatar
steve we where 3205lbs
our car and one of our 427s are down in your neck of the woods (Keith Craft )
ESP th 400 with brake hughes converter made to our specs
ford 9 with 360 gears
m/t "s" tires
hyd cam
you what to know more just let me know i will give anybody who wants to know all the exact specs
Old 01-11-2004, 02:41 PM
Worm Boy's Avatar
Thanks alot Ken!
Old 01-15-2004, 06:35 PM
Moderator
BADZ's Avatar
Thinking of running 8's Steven? You better be ready to spend major $$$$$$$$...
Old 01-16-2004, 05:52 PM
Worm Boy's Avatar
Old 02-11-2004, 10:10 PM
ONEBADWS6's Avatar
Talking
Holly **** I need spots!
Old 02-12-2004, 01:49 AM
wicked 98z's Avatar
Or do some jetting up and say some prayers Good luck, Hell your cars got to be getting close
