Drag Racing Tech
Manual brake conversion and pedal not returning?
Old 05-10-2010, 03:50 PM
Tricked-Out-Toy's Avatar
Default Manual brake conversion and pedal not returning?
Installed a manual brake kit from Midwest and the pedal will stay pressed down? Theres no binding in the rod end linkage, we're running aerospace calipers up front and stockers in the rear. Anyone have a clue why you have to reach down and pull the pedal back (or stick your toe under it) in order to release pressure?
Old 05-10-2010, 04:15 PM
Jon@Texas-Speed's Avatar
Make sure you didn't over-tighten the jam nut on the brake pedal itself. If it is too tight it will bind and actually not return correctly.
Jon
Old 05-10-2010, 05:03 PM
DMH Fabrication's Avatar
What Jon said and make sure there is no air in the brakes as well.
Old 05-10-2010, 07:43 PM
Broke EF's Avatar
Eric made a point to tell us that you need a washer between the pedal and the heim joint so that it wont bind. Just something I remember him saying that goes along with what the others have said.
Sean
Old 05-24-2010, 11:09 AM
So nobody has needed a return spring? Im hoping to get a look at it in the next few days. its a really annoying problem..
Old 05-24-2010, 12:52 PM
Fireball's Avatar
mine would do that until properly bled.
