Drag Racing Tech
HEEEEEEEELLP! please
Old 05-12-2010, 03:12 PM
phatasp's Avatar
Default HEEEEEEEELLP! please
My goal this summer was to run 10anything. last year
i ran 11.20 at 122mph. Over the winter I put on qa1r,s bogart big and littles. took out about 100lbs and took out the swaybar. last sunday I ran a 11.03 at 124. I thought for sure that would do it. I.ve got a A4 with a 3400 stall .My best 60ft last year was 1.67 this year was 1.59. running a moser 9in with 3.50 gears. do I need a bigger stall?Better gears? both? also running 275/50/15 mt drag radials. Almost full weight 02 trans am with a vortech supercharger, dart heads,fast intake.I know I,m almost there just trying to figure the best way to get there. I would appreciate any advice. Thanks Mike
Old 05-12-2010, 03:22 PM
mustang281man's Avatar
a 3.89 gear would get you there, a 4.11 might be a little to much. what rpm are you running it to?
Old 05-12-2010, 03:54 PM
phatasp's Avatar
crossing the line at 6100
Old 05-12-2010, 04:45 PM
3.89 would be the best choice then unless you want to spin it over 7000rpm
Old 05-12-2010, 11:11 PM
TS6
TS6's Avatar
I'd go 4000-4200 stall and try to remove more weight.
Old 05-13-2010, 12:57 AM
Man-Crush Warning
01sscam's Avatar
Remove another 100 pounds.
Old 05-13-2010, 01:12 AM
00MaroonZ28's Avatar
You can probably get away with 4.11's if you spin it up to 6700. They definitely will make a difference. It made a big difference on my car going to the 4.11 from 3.73.
Old 05-13-2010, 01:20 AM
phatasp's Avatar
I think the first thing I,ll try is the 3.89 and lose the rear seats and see how that goes eventually I do want to get a bigger converter from what i.ve read a 4000 sounds pretty good, leaning towards a Yank. Just wanted to get some ideas from people thats been there done that, THANKS
Old 05-13-2010, 01:24 AM
take the seats out, add a front bumper brace, pull the carpet and insulation and put in lightweight carpet. That'll drop about 175 lbs there.
Old 05-13-2010, 01:26 AM
phatasp's Avatar
I think 6700 would be ok and if it seemed too much I could go with a taller tire
Old 05-13-2010, 01:44 AM
Exactly, you'll like the get-up of the 4.11's. They just suck if you daily drive the car around.
Old 05-13-2010, 01:52 AM
StreetSilverado's Avatar
Try putting 4.33's in there....you'll love them!
Old 05-13-2010, 01:54 AM
phatasp's Avatar
thats not a problem, dragstrip and car shows is about the only time I drive it.
Old 05-13-2010, 02:10 AM
Go for it then. You'll probably have some trouble making the traps in 3rd with an A4
Old 05-13-2010, 04:41 AM
Race your car!
JL ws-6's Avatar
I'd leave the gear alone and get a converter built to the car, and try to get some more weight out, see what that gets you first. You up the boost, and next thing you know you'll be running out of gear.
Old 05-13-2010, 10:10 AM
Put the 4.33's in there and then see how you like the boost
I love internetz
Old 05-13-2010, 01:53 PM
Oh, go on a diet and take the biggest **** of your life before you run.
Old 05-13-2010, 02:36 PM
AChotrod's Avatar
Tallest rear tire you can fit and the 4.33s sound good to me also. Just look at all the SE/SS race cars, Huge gears (4.56-4.88s and huge tires(30-31s). Those cars straight fly for the HP they have.
Old 05-13-2010, 03:57 PM
phatasp's Avatar
LOL,pretty much what my wife said when I showed her the timeslip.
Old 05-18-2010, 07:26 PM
phatasp's Avatar
I ordered 295/55/15mt drag radials and a 4.10 gear , what do you think? Will I still be going through the traps at too high of rpm, or should I go with the 3.89
