Drag Racing Tech
408ci 88mm turbo Camaro Drag Build
Old 08-29-2010, 09:22 PM
jcoosi's Avatar
Got a chance to do a little work today.I installed the battery relocation bracket,kill switch,and circuit breaker.
Also made a block off plate to mount my rocker switch panel,a few gauges,and the window switches.Needs a little more trimming around the edges and then I will cover it.
Old 08-29-2010, 10:01 PM
repo's Avatar
functional
Old 09-06-2010, 10:16 PM
jcoosi's Avatar
Have a few udates
Mounted the fuel cell in the trunk
Also installed dhm fabrication cf door panels
Installed dhm fabrication steering column
Made a plate for the window switches and turn signal switches
And installed rocker panel switches
Old 09-06-2010, 10:18 PM
badss_02's Avatar
I've seen that car in person... Awesome platform
Old 09-07-2010, 07:49 PM
repo's Avatar
It is awesome, but it will be more awesome after he rebuilds the whole car his way.
The only thing he is gona reuse is some plastic, the body, and the rear-end.
Old 09-21-2010, 08:36 PM
jcoosi's Avatar
Well some parts have started coming in.I went and picked my power glide and neal chance convertor from the transmission shop the other day.Ordered a flywheel but the wrong came in so have the right one coming.My bmr crossmember came in.
Went to my buddies shop to day to pick up my cam,lifters,timing chain,and oil pump
Also picked up some of his old gauges,FAST setup,and ATi balancer
My midplate also showed up from Madman so I can start assembling the car.
Still waiting on heads and rocker arms.Maybe soon it will run.....
Old 09-23-2010, 10:16 AM
TAHOE5.3's Avatar
How many gallons is your fuel cell?
Jeff
Old 09-23-2010, 10:26 AM
jcoosi's Avatar
Jeff
I cant remember if it is a 10 or 15.I will check.
Old 10-24-2010, 01:35 PM
jcoosi's Avatar
Well more parts arrived so I can start assembling the engine and putting it in the car eventually.
Front plate,mid plate and solid trans mount
Power glide,tci flexplate,neal chance convertor,lokar dipstick tube
Speed inc valve covers,arp head studs,and meziere water pump
Yella terra rockers
Trick flow 235 cnc heads
Old 10-24-2010, 04:30 PM
The Guy in MY 99TA's Avatar
where did you get that front motor plate? if looks as if a/c and alternator would almost work with it... almost anyway
Old 10-24-2010, 05:08 PM
jcoosi's Avatar
Got it from here http://www.aeicnc.com/
It is setup to run an alt on either side depending on how you have your exhaust setup.
Old 10-24-2010, 08:14 PM
  #32
Orangepeeler's Avatar
Is the mid plate from there too? I went to their site and they list one in steel but no picture of it. Thanks, Mike.
Old 10-25-2010, 07:33 AM
  #33
jcoosi's Avatar
Mid plate is from madman
Old 10-25-2010, 10:51 AM
  #34
White.Lightning's Avatar
Nice buildup
Old 10-25-2010, 09:02 PM
  #35
Ok, thank you very much.
Old 10-26-2010, 01:41 PM
  #36
jcoosi's Avatar
Valley cover came in today
Old 11-14-2010, 08:02 PM
  #37
jcoosi's Avatar
Had a buddy stop by this Sat so we assemble some of the engine.Installed oil pump,timing chain,head studs,cam,lifters,and heads.
Old 11-16-2010, 06:50 PM
  #38
MelScrilla's Avatar
Good looking build, I like all the custom work. Whats the plan for the car all out race or some street time too?
Can't wait to see what that 408 does with the 88 on the track, everyone says 408 is to big for a 88 in a dedicated race app but I want to see if it works.
Old 11-16-2010, 09:20 PM
  #39
jcoosi's Avatar
It will serve dual purpose.
Im interested to see how it works out also.
Old 11-17-2010, 01:40 AM
  #40
Reject's Avatar
really digging the progress pix, quick question but are you going to run a bulkhead for the fuelcell being inside of the car?
Quick Reply: 408ci 88mm turbo Camaro Drag Build
