Drag Racing Tech
Super Victor Intake Manifold
Old 05-14-2010, 01:10 AM
Restricted User
Zero4488's Avatar
Default Super Victor Intake Manifold
I'm planning on going with the Super Victor intake with the High Flow Elbow....just curious to what you had to do, if anything, to get it to fit. I've heard their are some clearance issues and I just wanna know exactly what I'm getting myself into. Also I will be running the edelbrock fuel rails, I know the factory ones don't work....
-Dave
Old 05-14-2010, 01:14 AM
StreetSilverado's Avatar
-Dave
If you go with the High Flow Elbow more than likely you'll need a taller hood. Get ready to do some cutting in the windsheild cowling too.
Old 05-14-2010, 01:22 AM
Restricted User
Zero4488's Avatar
VFN 5 inch sloped hood is already en route...cutting shouldn't be an issue either....how much material has to be removed?
Old 05-14-2010, 01:37 AM
This was the "rough cut" of when I first cut it. I'm to the point now that I might go ahead and cut the whole cowling out and lose the extra weight. It's a pain in the *** getting behind there with a 4150 style throttle body.
Old 05-14-2010, 06:04 AM
Fireball's Avatar
since you are getting a tall hood...try a carb spacer too to help distribution in the intake
(I had roughly 3" of room between the top of my elbow and the bottom of the hood without a spacer)
is the hood you are getting extended to the windshield? if so cut the cowl off all the way back to the base of the windshield and box it in...gain tons of room
Old 05-14-2010, 07:05 AM
Race your car!
JL ws-6's Avatar
Dogbox the windshield un the middle up to where the hood rests on the windeshield, and gain the ability to take the motor/trans out as one piece.. you can go strait back to the main firewall if you have the 5 inch pin on vfn hood
That, along with removing the upper radiator support, (or making it removable) will REALLY make some room!
Old 05-14-2010, 07:31 AM
6point7s14's Avatar
Can anyone say how much higher this sets than an ls style intake? I have it all in a 240 and was wondering the height of it
Old 05-14-2010, 07:46 AM
Fireball's Avatar
the intake itself is probably about the same height as the LS intake....its the elbow, TB, etc that makes it start growing FAST...problem is part of the carb flange is under the cowl.
Old 05-14-2010, 09:46 AM
6point7s14's Avatar
^^^ its not a windsheild cowl prob on my 240 lol. Its hood problem. Just need better intake for my motor but if I have to build a cowl for hood it prob would look silly
Old 05-14-2010, 02:08 PM
Restricted User
Zero4488's Avatar
Thanks for all the input....and yes I ordered the one that is extended to the windshield....what is the best way to cut the cowling away? And what do you mean by box it?
Old 05-14-2010, 03:29 PM
Race your car!
JL ws-6's Avatar
Look at The new car that Tom Kemph is building, you can see what he did in the center.
That's a cutoff wheel, and alot of fab work.... but I'm 100% sure that once that's done you can run a dual quad tunnel ram if you want.
Old 05-14-2010, 03:52 PM
Restricted User
Zero4488's Avatar
Not sure who Tom is but if you have a link to his build that would be great.....
Old 05-15-2010, 05:19 AM
Race your car!
JL ws-6's Avatar
Look in the racing section for the build called "money shot"
It's almost an outlaw car... but with just enough to keep it in the stock suspension catagory (and an amazing build as well..... thing's really been pushed to the limit, both technology wise, build quality wise and well... probably cost wise too)
It will for sure be running in the 6.xx at well over 200 mph when it's done.
Old 05-20-2010, 12:56 AM
BOBthe4dH8r's Avatar
is the performer rpm shorter than the vic jr? is anyone running it?
Quick Reply: Super Victor Intake Manifold
