26 or 28 ET Drag
vette=lack of penis
26 or 28 ET Drag
I am trying to get some info together. Are most guys running 28" ET drags or do you think a 26" would suffice most of the LS1 modded cars. I am talking on more of a heads and cam type car. With or without N2O. What has been your experience. Thanks, Christopher
depends on your gearing and power band.
a 26 with 3.73's will work far far better than a 28 with 3.73's. but a 26 with 4.56's might run out of gear where a 28 wont.
LS1Tech Co-Founder
I vote for 26's, I think 28's on a conservatively geared H/C car are overkill.
I see streetracers running 28's on the street but they need to overcompensate for racing on cold asphalt. I bet most of the 28"'d street racer guys are undergeared and don't hit low 1.5's at the track.
Motorboater
i can't remember if i told you this when you asked over the weekend so i'll say here.
i think you should try the 26 first, same tire i have 26X11.5X15 at a nice low PSI, you have enough suspension and the right gear to hook it at a decent track I believe.
if you spray, no way the 26 will hold, will need a bigger tire for that.
LS1Tech Co-Founder
Well it depends.
A 28x9x15 ET Drag is like a narrow 27, so it fits no problem (15x8 rim).
28x10.5x15 stuff does not just go in, you end up having to clearance on the inside to make them fit.
If you can DEAD hook with a 26" slick (hey, how good is your track?) then you're better off with it, gearing issues aside. But, if ya can't hook ya can't hook.
Originally Posted by SilverGhost
holy crap silver98..i didnt' realize you were on a 26.
gives me some hope lol.
