Drag Racing Tech
debating on going from M6 to A4/A3
Old 05-23-2010, 11:44 AM
98mysticZ's Avatar
Default debating on going from M6 to A4/A3
ok my combo is 408/ m6 9 inch... and i cant get this bitch to leave to save its life... so i am thinking about ditching the m6 for an auto... how many of yall have done this? i went out on a 28x10.50 and was running .6 slower in the 1/8 on motor and havent sprayed it yet with the new plate kit.
best 1/8 n/a pass on a 26 was 7.41@96.65 and it had a 1.74 short time
right now on a 28 its 8.03@94.5 with a 2.3 60 foot.... so i am thinkin about going to a 26 again or ditching the m6 for an auto.. what do yall think
strang front adj with a 300lb liner spring
umi torwue arm with relocation
full umi rear susp (non adj lca)
9 inch with 3.90 and trutrack ( broke the trutrak on my last pass getting a spool)
stock rear springs and shocks
leaving at 5500 with 20lbs in the rear it would hook and BOGG so i either need to leave higher or smaller tire or taller gear what do yall think
Old 05-23-2010, 12:50 PM
daniel6718's Avatar
you cant go back to 26's...it wont hook very well...you need the 28's
before going auto tryin leaving on spray...
if you go auto do an 80-e if you want to drive it a bunch
Old 05-23-2010, 01:47 PM
00T/AWS6's Avatar
What gear do you have in the rear?? I was pondering going the same route, goin from M6 to A3 but for slightly different reasons. You just have to take some time and dial everything in.
Old 05-23-2010, 02:09 PM
BES Stroked Nova's Avatar
i went 1.47 60 ft in a 3800lb 6 speed car with 26" mt's with stiff sidewall.
but I have 4.86 gears. cars been 10.97 at 125.
you need WAY more gear than a 3.91.... thats just the start. and take that air pressure down to around 14.
Old 05-23-2010, 02:14 PM
MYSTIC-1SC's Avatar
go auto and never look back. U wont regret it.
Old 05-23-2010, 02:58 PM
Tally TransAm's Avatar
auto will be more consistent, but to me part of the fun is getting it to hook.
keep the 28's,ditch the 3.90's and run 4.11's, 4.30's (depending on rpms) and get a two step, makes it much more consistent to see what suspension changes are doing. with your setup and a rear drag bar you should be able to do 1.4's - 1.5's
Old 05-23-2010, 05:31 PM
dnkynrbk's Avatar
Ditch the 6 speed. I run a A3 t400 with neal chance converter 3:73 gear and a 15x10.50 et drag. 28 inch tall tire. My set up runs perfect. I also run 315lb qa srping on the front.
But my car is a track only and a few car shows. Esp with the nitrous stall
Old 05-23-2010, 05:52 PM
01SS99red's Avatar
to the op what gear are you running? Im a n M6 with 28in tire 4.56 gears cam only and the car leaves 1.5X all day with ls7 clutch setup. I think you need more gear these M6 car n/a realy need the 4.56 gears to get it moving.
Old 05-23-2010, 06:09 PM
94Z28rag's Avatar
Waaaaay undergeared. That being said, I just made the M6 to A3 jump before I got my project done because I know it's the right decision in the end.
Old 05-23-2010, 06:12 PM
SS4Luck's Avatar
i have 28" tires, 411s stock suspenion and am cam only and have no problem hooking and going 1.6X consistantly. I come out around 5600 and it just straight goes. Try coming out of the whole a little harder and maybe staying into the clutch a bit to keep it from bogging. There is no reason you shouldnt be hooking, you either need the driver mod or more practice
:edit: i also have 17 lbs in the tires, at 20 they were un predictable and i hated them
Old 05-23-2010, 06:37 PM
98mysticZ's Avatar
its a 3.90 rear gear but i do have a plate kit so i will be leaving on dope.. BUT just dont understand why i lost so much et with just a tire change... i do have a 2 step left at 5500 last pass and got a 1.97 short and broke the trutrack... so
Old 05-23-2010, 07:55 PM
Randy WS6's Avatar
I run a M6 for 8 years and changed over to a 4l80 FMVB , and I wish i had done it years ago. My 60ft in my sig.with the auto
Old 05-23-2010, 11:32 PM
Restricted User
Zero4488's Avatar
Ditch the 6 speed and put a auto in it....when I switched to the TH400 it was the best move I ever made....
Old 05-24-2010, 12:08 AM
tomz28's Avatar
ive gone 1.67 on a 4500 drop with 3.42 on a 275/50/15 MT DR. 2 steps help alot my freind. my 60 foot is not great but id like to try a 5500 drop LOL
Old 05-24-2010, 12:54 AM
Man-Crush Warning
01sscam's Avatar
You need to launch the car A LOT harder and lower that tire pressure as well.
Old 05-24-2010, 11:18 AM
if you got the gear in there for the spray, spray that bitch!
your just kicking yourself in the *** trying to get the car to work, then spraying it. it changes everything. if your wanting the car to work on spray, work with that.
I had to launch 7200-7500 with I had just 4.30 gears to keep the car from falling on its face.
Old 05-24-2010, 11:30 AM
bjamick's Avatar
Go ahead and picture my situation with 3.23 rear gears and my t56 swapped ride. It's a PITA to get out of the hole. You got it much better than I do.
Old 05-24-2010, 07:10 PM
98mysticZ's Avatar
yea after i get the spool in i am getting the tune finished for the bottle and its already got a 2 step just need to wire in a pedal switch to turn off the bottle.. and then i will drop it to 14 psi and leave at like 5500 and HOPE i dont break something else.. ... i am not scared to spray in "mexico" just digs break **** lol....
Old 05-28-2010, 02:12 PM
Oh4GTO's Avatar
I want my money back!
