Drag Racing Tech
Motor plate and Mid plate?
Old 05-25-2010, 04:45 PM
OddballLt1's Avatar
Default Motor plate and Mid plate?
If you run a motor plate, is a mid plate mandatory or just extra insurance?
Old 05-25-2010, 05:45 PM
Ph.D. in HUBRIS
custm2500's Avatar
I beleive you must run a mid plate. Never seen one without the other. That is allot weight and stress to put on one fairly thin piece of metal since the next mount would be on the trans.
Old 05-25-2010, 05:50 PM
Mr. French's Avatar
Depends on how much power you make.
Old 05-26-2010, 08:11 AM
6 & 8 Second Club
mrdragster1970's Avatar
A lot of us used just the front plate. It's just a replacement for the motor mounts.
As I got faster I did add the midplate, but ran the front only for several years.
As long as the limiter is done properly, you should be OK for a mild engine.
Would I ever run the front only again, no, I've learned a lot since then.
If you use both, it makes everything so much stronger, and stable.
Old 05-26-2010, 08:38 AM
LS1TECH Sponsor
Steve Burger's Avatar
You can get away with just the front plate but as stated abouve4 you are sacrificing strength.
What are your goals?
Old 05-28-2010, 01:25 PM
OddballLt1's Avatar
Im slowing putting a setup together, I want to build a stock bottom end H/C LT1 that run low 10's/ high 9's. I want to get the chassis/ suspension done first, then get to the motor/transmission.
Old 05-30-2010, 08:46 AM
LS1TECH Sponsor
If you are looking at plates, I would do both at the same time. For your goals you could do just front plates. But wa all know this hobby is like a meth habit, ya just get to keep your teeth.
The reason I say both at the same time is that it will effect how your converter is built. The hub on the converter is specific to the thickness of the mid plate or lack of a plate. On a 9 sec car you will be fropping some cash on a converter. May as well only do that once.
Old 05-30-2010, 10:20 AM
6 & 8 Second Club
Plus headers, I had to get different headers with a mid plate.
I don't know anything about these cars, but on mine I had no choice.
Old 06-01-2010, 07:02 PM
z28racerlt1's Avatar
I run both plates with my LT1 motor. It was the best thing ever. More header room, better strength than motor mounts, and the final thing it makes putting the motor in alot easier. Also when you pull the trans out you don't have to do anything with the motor. It just sits on the mid plate.
I highly recommend a enigne limiter though. I didn't put one on at first and broke a heim on the torque arm one day. It bent the motor plates and slammed the carb into the cowl of the car. Not a good day.
I now run the limiter.
ken
Quick Reply: Motor plate and Mid plate?
