Drag Racing Tech
Need inexpensive aftermarket Valve covers???
Old 06-01-2010, 06:17 PM
TexasVortexx's Avatar
Arrow Need inexpensive aftermarket Valve covers???
What aftermarket valve covers are you guys running?
I currently have 1 inch spacers but they leak so I am looking for a set of inexpensive tall covers to replace them with.
What are your thoughts?
TIA
Old 06-01-2010, 07:11 PM
03 BUSA's Avatar
Good luck, I have been dealing with the seeping spacers as well for over a year now. Just haven't found a decent price on a set. Seems those things are made of gold. LOL
Old 06-01-2010, 08:28 PM
Mine are more than just seeping at this point. On the dyno today they blew oil everywhere
I have found these on Ebay, they look decent for the price but I would need to drill and tap for my crankcase ventilation
http://cgi.ebay.com/ebaymotors/SBC-C...item19bcbe905c
Old 06-02-2010, 06:29 AM
WKMCD's Avatar
I don't know how tall you need but I run GMPP VC's and they are considerably taller than stock. I think they're about $225 for the set.
Old 06-02-2010, 08:10 AM
Internet Mechanic
BlackScreaminMachine's Avatar
JL have some Nasty Valve covers that had the coil pack elevated, needed longer wires but worked great.
Old 06-02-2010, 08:43 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
I used gasket maker to seal my spacers to the valve covers. Eliminates the extra seam that way.
Old 06-02-2010, 10:12 AM
Nasty N8's Avatar
I do get alot of complaints about the spacers leaking. Quality and cheap don"t really go together. I have no issues with our covers leaking. Our custom Fabricated covers start at $350 a pair.
Old 06-02-2010, 12:23 PM
Broke EF's Avatar
We have the cheap e-bay covers (probably the same as above, but from a different seller). We went with the non polished, tall covers, with NO provisions for coil packs. They seem decent, not top tier quality, but maybe better than you would expect for the price. I didn't feel bad drilling them and welding in fittings, I can tell you that.
We added some -10 bungs for breather tanks, and powder coated them S&S crinkle black.
Sean
Old 06-02-2010, 01:29 PM
Race your car!
JL ws-6's Avatar
I had a set of nasty ones, they were great, took a little work to get them positioned just right, but when they were sitting on the head right they never leaked a drop... just have to play with them (front to back) to get it just right.
I dunno how good they are, but there's a TON on chinabay for sale that look decent and are pretty cheap too.
I did see, a nice set of C5R ones on there for sale.... for 699.99 LOL. Yeah right.
Old 06-02-2010, 05:11 PM
LS1SpeedAddict's Avatar
I bought those exact valve covers for my engine. They fit great and look great. I havent raced with them yet but Ive ran the engine and the seal. F*ck spacers.
Old 06-02-2010, 07:33 PM
Race your car!
JL ws-6's Avatar
ls1 you bought the same exact ones, they seal up good and fit right?
If so... I'm gonna have to snag a set of those, for the 104 bucks plus shipping I dunno how you can go wrong.
Old 06-03-2010, 04:47 PM
everything fits right buy I had to shim the oil dip stick because they are taller. The polished finish is top notch. They have sealed good for me so far. I couldn't see spending 5 times that much for the same thing and its not even polished.
Old 06-03-2010, 06:22 PM
Good info guys. I have heard that these may require some grinding too on the inside to clear the big aftermarket roller rockers.
Old 06-03-2010, 08:10 PM
Race your car!
JL ws-6's Avatar
That could be a problem for me. I have some very large rockers that are bound to be an issue....
I may still get a set to try, see what the problem is and see how workable it is.
As for the dipstick, I'm putting a moroso pan on so that thing's useless at this point, I was going to just figure out what the engine will hold (with the remote filter and lines, and the accusump) and once I have that figured out, drill/tap the dipstick hole and not run one.
With the way I change oil (every track trip, so figure ever 5 to 6 runs average) I see no reason to even check it, just figure out what it takes, put that # of qt bottles up on the motor, drain, change filter, and before the hood goes back on put all the bottles in... pretty dummy proof IMO.
Old 06-03-2010, 08:22 PM
I've got the Moroso street/strip pan and Moroso said the stock stick is accurate, was true. Between my remote lines and monster oil filter I hold an additional 1.75 quarts
Old 06-03-2010, 09:17 PM
trans2000am's Avatar
how well will the ebay ones handle boost? im in the same boat need new covers but dont know what one to go with, really cant afford to drop 500 bucks on some.
Old 06-03-2010, 09:41 PM
Broke EF's Avatar
They will handle boost just fine with a 5/8" hole in each one.
Sean
Old 06-03-2010, 09:50 PM
What kind of rockers do you have? I'm running jessels and don't have a problem but there not the big adjustable ones for solid lifters.
Old 06-03-2010, 09:57 PM
Race your car!
JL ws-6's Avatar
A custom set of Crower solid roller rockers, 1.8 ratio that are for the ET ls7 head.
Old 06-04-2010, 08:05 AM
buzz12586's Avatar
I'm also interested in what alternatives are out there. Nasty's valve covers look great but I can't justify $500+ for them.
Quick Reply: Need inexpensive aftermarket Valve covers???
