Drag Racing Tech
Guys with Lokar throttle cables in here please
Old 06-01-2010, 07:23 PM
FASTFATBOY's Avatar
Default Guys with Lokar throttle cables in here please
How did you hook up the pedal end? Did you drill the pedal?
Did you cut the stock cable, slide off the little deal that locks into the pedal and slide it on the Lokar cable?
Old 06-01-2010, 08:41 PM
Hippi's Avatar
DING! I actually had an old cable laying around that I pulled the plastic retention clip off of
Old 06-01-2010, 08:45 PM
Randy WS6's Avatar
I cut the stock cable.
Old 06-01-2010, 09:15 PM
FASTFATBOY's Avatar
The hole in my firewall is too big, did you guys put washers on the cable to make it work? Thats what I did.
What a pain, the cable did not take kindly to being done that way. A few strays popped up.
Old 06-01-2010, 09:27 PM
z28racerlt1's Avatar
If you use a stock cable from a 3rd gen camaro it will fit the pedal assembly perfect. It will also fit into an aftermarket throttle cable bracket(like a carb style bracket).
The only thing I had to do was cut back the plastic around the cable towards the throttle end. Otherwise it would not allow for full throttle.
ken
Old 06-01-2010, 09:35 PM
FASTFATBOY's Avatar
ken
PIcs?
Old 06-02-2010, 03:55 PM
I'll go into the trailer and get some for you. cant get the pedal shots until the weekend.
Ken
Old 06-02-2010, 04:09 PM
I got one of the peedal also.
Hope this helps.
Ken
Attached Thumbnails Guys with Lokar throttle cables in here please-1.jpg   Guys with Lokar throttle cables in here please-2.jpg   Guys with Lokar throttle cables in here please-3.jpg   Guys with Lokar throttle cables in here please-4.jpg   Guys with Lokar throttle cables in here please-5.jpg
Old 06-02-2010, 05:05 PM
FASTFATBOY's Avatar
Thanks man. I wish I would have known this before I bought the Lokar deal.
Old 06-02-2010, 07:07 PM
Well if you get sick of messing with it, the GM cable was about 40 bucks.
Ken
Old 06-02-2010, 10:44 PM
studderin's Avatar
Ive also heard guys say getting one for a "86 blazer" works well too?
Old 06-03-2010, 05:59 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I'm running a V6 3rd gen cable and picked it out of the junkyard for $10.
I had to modify it like z28racer said
Old 06-04-2010, 09:38 AM
Taubr Unit's Avatar
Why not just use the stocker?
Old 06-04-2010, 10:10 AM
ryarbrough's Avatar
Stocker won't work with a carb or an a 4bbl tb
Old 06-04-2010, 03:06 PM
Z28/2002's Avatar
Exactly it is WAY too long
Old 06-04-2010, 04:13 PM
suicidal racing's Avatar
man glad i seen this thread..cool deal..junk yard 3rd gen hunting tomarrow
Old 06-06-2010, 08:28 AM
FASTFATBOY's Avatar
Wellll I started the car last night, the first time I stepped on the pedal it pulled the stop right through the factory black plastic deal I put on there. I HOPE I can get the cable back in and out of the sheath once more to get the clevis it came with back on it. It will work I think as long as I tie rap it in there.
Old 06-08-2010, 03:26 PM
Z28/2002's Avatar
I put a couple screws in mine like z28racerlt1 did
Old 06-08-2010, 03:57 PM
buzz12586's Avatar
Subscribing to this for future reference.
Old 06-08-2010, 05:05 PM
FASTFATBOY's Avatar
I took the cable back out, put the clevis end it came with back on, put it in the pedal and took some Chanelocks and squeezed the hole shut at the top
Quick Reply: Guys with Lokar throttle cables in here please
