Swaping in a th400/350
For what you want 350 hands down. They can EASILY be built to handle what your looking at. Weight will do a lot to help keep them alive.
Its not a huge difference but for what your saying you want i dont think theirs much question.
This is the trans Im looking at
have a TH350 Long tail shaft tranny for sale bought this for my malibu but never installed it. was behind a 383 Stroked s-10 from what i understand and they went to a powerglide.
JW Bellhousing that would have to be re certified, i called them up and they said they can do it if you wanted to get it done.
Kolene steels, Red Alto, Kevlar line race bands, reverse pattern manual shift valve body. Also has a deeper trans pan looks like it can hold an extra quart of fluid.
I have a M6 as most of you know,
Most of the stuff in the trans section is for LS1s and not LT1s so I have a couple questions.
What All do I need for the swap.
Trans
converter
flexplate
shifter.
Trans cooler and lines
A4 console (not needed but better looking)
Is that it? Am I missing something?
I read you can use a M6 cross member, if I get a long tail shaft I can reuse the DS, wire the trans to the clutch switch, use the M6 computer tuning, and just take out the clutch pedal
Sound about right??????
Will all standard SBC stuff work with a LT??? I know the LS1 needs some shims, different flex plate or a longer LS1 style pilot snout on the TC.
Trans
converter
flexplate
shifter.
Trans
converter
flexplate
shifter.
Trans
converter
flexplate
shifter.
Trans
converter
flexplate
shifter.
Trans
converter
flexplate
shifter.
