Drag Racing Tech
wtb external fuel pump system
Old 06-21-2010, 03:26 PM
wichoms4's Avatar
Default wtb external fuel pump system
i want to do an external fuel pump system.. im running the stock 98 tank.. who sells systems that can be used with the stock metal tank?
Old 06-21-2010, 04:12 PM
LS1TECH Sponsor
Steve Burger's Avatar
You would need to sump the tank. It may or may not be worth the effory over a cell.
Old 06-21-2010, 04:19 PM
wichoms4's Avatar
what would be the best option?
jose aka wicho
Old 06-21-2010, 05:33 PM
DMH Fabrication's Avatar
jose aka wicho
Is your mind made up that you want an external pump? Twin 255s in the tank are good for a decent amount of hp with upgraded lines from them to the rails.
If you go external and want the tank in the OEM location, you have to sump the tank or run something like Nasty Performance tank.
It really depends on what your goals are.
Old 06-21-2010, 05:38 PM
SS4Luck's Avatar
Give nate a call @ nasty performance. Hell take care of you
Old 06-21-2010, 05:40 PM
wichoms4's Avatar
sounds good, but im gonna be running a stand alone harness.. can you run this set up. im low on tech... sorry just need more info
thanks
jose aka WICHO
Old 06-21-2010, 05:47 PM
thanks
jose aka WICHO
Wiring shouldn't be an issue with any setup you pick. Normally to get better voltage to the pumps, you will run them with a relay and larger feed pwr wire direct from the battery or your power distribution block. Then you can either trigger the pumps to turn on with a trigger wire from your ecu (most any aftermarket ecu has a fuel pump on trigger) or you can wire them to a switch you turn on yourself. If you have any questions on wiring, feel free to PM me and I can go into more details.
Old 06-21-2010, 07:26 PM
wichoms4's Avatar
Thanks il pm you when i have made up ma mind.. mite just go with nastys fuel cell..
