View Poll Results: Tube or no tube
Tube
7
41.18%
No tube
10
58.82%
Voters: 17. You may not vote on this poll
To tube or not to tube.
Ph.D. in HUBRIS
I do tires for a living so conventional wisdom tells me to put a tube in my slicks. When I bought them many people said "don't run tube"
If you have tube type slicks vote if you have a tube or are running them tubeless. Thanks. If you have a comment of personal experiance please include an explination.
I figure the last thing I want is to wreck my car, myself, or somebody else. If you're running slicks and making the power to pull the fronts off the ground, then use tubes AND rim screws. I know I don't want to spin the rims inside tires that are only running 15psi of air to begin with...
To the OP - consider this: there are guys that make it well into the 10s on ten bolt rear ends. Does this mean you would? Maybe maybe not.
Will you be ok running without tubes? Maybe maybe not. If you do tube, just be sure to use rim screws. BTW, tubes are pretty light....I guarantee you won't notice a difference in your et or mph with or without them
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
28 x 10.5 stiff M/T with no tubes or screws. 1.38 on stock suspension. I know some that run them and say it helps. I guess I haven't reached that point yet
Derek
Derek
Exactly what Nathan said: No tubes
Permatex High Tack (keeps tires from rotating on rim)
I learned the High Tack trick after screwing my old stock 16inch five stars because the tire was moving. When i got my new Weld 15x10s I was looking to an alternative to screwing a new set of rims so I posted up and an old school racer told me to try High Tack. I was leaving in the upward 6k range at 13.5 psi cold and no slippage. This stuff works.
As far as the leak down problem, before mounting the slicks (without tubes) get some ajax liquid soap and completely coat the inside of each slick then sit them out in the sun and let them dry. Repeat this step about 3 times, this will almost eliminate the leaking, another trick I learned from an old schooler on this site.
Ph.D. in HUBRIS
My biggest concern is getting sepperations in the tire. Traditional wisdom says that tube type tires will sepperate like crazy since it doesn't have an inner liner to keep the air where it belongs. It seems as if that isn't the case at all.
Apparently no one has had a tire go to hell due to not running a tube?
