Drag Racing Tech
which route to take for tires?
Old 07-14-2010, 04:29 PM
senicalj4579's Avatar
Default which route to take for tires?
Right now I have street tires (Cooper Zeon 2XS Tires on zr1 275 40 17) and I was thingking on getting just 2 drag radial nittos (NT05R) for the rear. I figure I can change them out when I get to the track. What do you think? Or should I just go with a slick seeing how I will be changing them when I get to the track anyway?
Old 07-14-2010, 04:48 PM
AChotrod's Avatar
Since your A4 most DRs will work just fine
Old 07-14-2010, 05:01 PM
zracer323's Avatar
If you won't be driving on them all the time get MT ET street radials. They hook better than the Nittos.
Old 07-14-2010, 05:26 PM
so I will be fine running the front tires as is along with some drs in the back?
Old 07-14-2010, 06:07 PM
NoMoreFWD's Avatar
Yeah, you'll be fine. I agree with the M/T comment. They really hook, no need for slicks.
Old 07-14-2010, 08:53 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
X3 on M/T over the Nittos if you are only going to be using them at the track or very little road use. You will find their grip will work great even as you continue to add more power whereas a Nitto will have a finer line on consistently hooking.
Derek
Old 07-14-2010, 09:54 PM
Thanks very good advice. When everyone is saying get mt over the nittos are you talking about a slick or drag radial or street radial?
Old 07-15-2010, 07:25 AM
Internet Mechanic
BlackScreaminMachine's Avatar
ET Streets Is a Bias Ply type tire that has a DOT approval rating but has more Coreds and is a stiffer Bias Ply.
ET Drags Similar but are track only type tires, much softer side wall and different compounds
ET Street Radials The Drag Radial version with their own unique compound. Very sticky for a radial.
IF you get a ET Street Radial make sure you have line lock. Do not bother tying to power brake the suckers. I do not care how much water you have in the box.
Old 07-15-2010, 07:49 AM
94Z28rag's Avatar
MT ET Street Radial. I'll be running them on my setup (see sig).
Old 07-15-2010, 10:34 AM
I really need a line lock on those ET Street Radials? Im not a hardcore drag racer. Its mostly a streetcar. Does it matter?
Old 07-15-2010, 10:36 AM
Do you plan on street driving those? Whatever tires I go with will be meant strickly for the track. Im gonna buy 2 for the rear,change them when I get to the track,then change them back for the ride home
Old 07-15-2010, 10:49 AM
Internet Mechanic
A quick story.
Before I owned my LS1 m6 car I had a 383 LT1 High Comp 1994 Z28
It had a Moser 12 bolt at the time and a Smallish stall (2800 and 3.42 gear ratio)
Now mind you I know a WHOLE lot more now then I did back then.
Going to the track I got them wet in the water and staged to Power Brake Burn to get them ready. The car actually PUSHED through the Brakes, No matter how much I clamped and how much I punched the throttle, it was just STICKING and pushed the car through the line.
Subsequently it bogged off the line due to the stall and gearing issues.
So even in a auto car a Line lock works and is considered QUITE useful.
Another example is recently my Bro took ownership of a pretty done up 1987 Buick Grand National, Making 530 RWHP on Meth and has decent gearing. He cannot brake burnout the tires on the STREET. He tried all he could. He needed the Linelock to do any sort of burnout.
Old 07-15-2010, 11:55 AM
Originally Posted by BlackScreaminMachine
A quick story.
I understand that. Iv never been to a track yet so im a little green in that catagory. So if those tires stick that well then why would I need to do a burnout in the first place? My car is almost stock and it only put down 316 rwh and 333 rwt before headers+ory. Do I really even need to burnout with that low of power? I can just get the tires and do the lock later on when I have more power no?
Old 07-15-2010, 12:16 PM
Internet Mechanic
On a unprepped street type conditions getting the rocks and sand off the tire itself will help. A race track has a sort of "Glue" they lay down which assist in racing.
So even if you do not hit the streets, IF you do any street racing, its a good mod to have.
Just passing along a little knowledge.
Old 07-15-2010, 01:01 PM
94Z28rag's Avatar
I'll be driving to and from the track in race-trim. No changes other than tire pressure.
Old 07-15-2010, 02:29 PM
BaD AZz Z28's Avatar
I run a set of 315x60x15 et street radials and foot brake the burnout just fine
Old 07-16-2010, 08:31 AM
94Z28rag's Avatar
You don't need a line lock. I ran MT radials back when I was a bolt on car with 3.23s and a 2100 stall and had no problems foot braking a burnout...on or off the track.
Old 07-16-2010, 08:55 AM
Thats good to hear. I dont wanna have to worry about all that stuff yet,cause my car is just about stock.
Old 07-16-2010, 11:58 AM
7 Second Club
A line lock is nice to have, but not a necessity as far as I'm concerned. I have no trouble with my mickey thompson tires on my Formula, which was bone stock when I started using them. Just make sure they have good water in the burnout box and don't roll too far forward of the front edge of the water box.
Derek
Old 07-29-2010, 04:56 PM
How many passes would mt et street radials typicaly last me?
Quick Reply: which route to take for tires?
