rim spining inside tire...maybe need rim screws?
made the first passes of the season finally. noticed after the first motor pass the rim moved 1" inside the tire and the marks no longer lined up. after 2 more passes it moved maybe another inch. after the first nitrous pass the tire spun around to almost the 180 degree mark.
my questions are: will this ruin the bead on my tire and how serious of an issue is this? Will my 60fts be improved if i screw the rims? and one last thing, will the tire leak air if i screw the rims, now needing to run tubes?
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
A few other questions might help further your options:
#1- what kind of rim, size and are they brand new or used?
#2- how were the tires installed (dry, soap, glue, etc)
#3-what are you running for tire pressure?
#4-car power, 60 foot?
Some set-ups make it where screws might be needed, but fresh tires do need a little time to seat. Mine usually take 3-6 passes and move 1/2-2 inches on the slicks, but radials move little, if at all. Some use glue and the tires won't move at all. If you drill them, likely you might need tubes to help on air leakage, but it depends.
Derek
Derek
Now sure how your 60's are but, if youre spinning the tire on the wheel there is an issue.
First - anytime youre putting power down and it does anything put move the car forward youre losing in the 60' - 180deg on a 28" tire is over 40" of movement forward that you didnt get.
If the tire never seats and keeps moving - I would put screw them. And yes they will leak - silicone helps but wont fix it.
Derek
Derek
have you ever tried more pressure? 10 seems low for what most are running now unless you're in a big tire car
edit: with that much power this isn't going to fix the problem with the rims spinning in the tires. for that you'll most likely have to screw it, or try the permatex
Race your car!
I tried the same tire down that low, and it didn't work any better then running them at 11.5..... I'd put at least that in them.
You probably will need to screw them though, every tire I tried without screws moved, I finally just said to hell with it and screwed them. Tip on screwing the tires: use moroso's screws. They're a "touch" shorter then the std ones you get thru summit and the like, and this helps prevent the leaks a good bit.
9-Second Club
There ya go, and that point was probably below 11.5 or 12. 10 psi is too low. Lower does not always hook better, but it sure will cause other problems. Mine absolutely does not like less than 12 psi. I use 10.5" Hossiers on 12" wheels. Those hook better, with more air, than 10" wheels.
Race your car!
Rim width will affect how much air a tire likes as well, if you're on a narrow rim for the tire, you'll most likly need less to keep the contact patch flat, too much air will cause the tire to "bubble" more.
Wider rim, like what Ed is using it will take a littl more since the sidewall is spread out more, and the contact patch is naturally spread due to the rim width... added air is needed so that the entire contact patch can work.
Varying rim width, is sort of like playing with air pressure in relation to what the contact patch of the tire looks like.
Example, same tire, on a 8 inch vs 10 inch vs 12 inch rim, wider the rim the more flat the contact patch is kept. Therefore, the more air that is needed to keep the center of the tire on the ground right.
Race your car!
It does, rim width also affects the contact patch, wider rim with the same tire will increase the contact patch, and high speed stability, which is a nice side effect.
You can, go too wide, causing the sidewall to be stretched too much, then they won't work right, and you can go too narrow, causing the tire to be too much of a bubble.
Example, a 10 inch tire can work on an 8 10 and 12 inch rim, try it on a 6 inch rim and it won't work for **** if it will even fit, and if you tried it on a 14 inch rim, if it would even fit, it wouldn't work for **** either.
Tire height, also affects what you can put the tire on for a rim... a 33x10.5 tire can go on a 15 inch rim. Reason being, isn't just tread width, it's carcass width.
The tire's carcass width has a large effect as to what rim width will work as well.
Alot of factors help determine what rim width will work, and what effect it will have on the tire.
