Drag Racing Tech
Converter slip problem?
Old 07-31-2010, 03:47 PM
355z28's Avatar
Default Converter slip problem?
I believe I have a converter slip problem. I keep calculating between 22-26% slip. Is this right? What am I leaving on the table?
26" hoosier QTP
7.53 et 1/8th mile
going through the traps at 5800 rpm @92 mph
Any help would be appreciated!
Thanks,
Austin
Old 08-01-2010, 10:30 PM
Vortec355's Avatar
What does the RPM drop between gears?
Old 08-02-2010, 12:02 PM
355z28's Avatar
The rpm hardly drops and then shoots right back up to 5k or so. When it drops it makes an odd tone (kinda like a VTEC would lol) and picks up rpm it sounds like it almost down shifts but it doesnt.
Old 08-05-2010, 06:24 PM
Firehawk441's Avatar
Use this calculator to determine % converter slip...
http://www.tciauto.com/Pages/418/calculators.aspx#4
Old 08-11-2010, 05:11 PM
Packy's Avatar
What is a normal percentage range for converter slip?
Old 08-11-2010, 05:41 PM
SuperSlow02's Avatar
Is this for 8th mile? Most ive seen are for 1/4
Old 08-11-2010, 07:40 PM
droksformula's Avatar
From what I have seen elsewhere on the board, around 4% slip unlocked is good.
Although you have to take into acount various converter slip and tire growth, the formula to tell what rpm you should be at for a given mph is. . . . . .
Mph x 1056 x trannsmission gear ratio x rear axle ratio ÷ tire height ÷ 3.14159 = rpm
(if the tire height was constant and there was no drivetrain slip)
Old 08-11-2010, 08:12 PM
Packy's Avatar
Using the formula on TCI's website mine comes out to being around 11%. I thought that I may have had a slippage problem lately.
Old 08-12-2010, 10:22 AM
355z28's Avatar
They say that 7-12% is normal in the 1/4. Mines sitting around 10-12% after I finally went to a 1/4 mile track.
Slip isnt always a bad thing. To much slip is. I spent a lot of time talking to ATI and Circle D on this thing. Im sitting alright. But when I spray it will be a different story im sure.
Old 08-12-2010, 06:18 PM
I have found that 9-10% slip performs best for me. Tighter effects short times and looser effects top end... I've pulled many converters over the years to get what I want out of them. I've moved to the bolt together converters now to make the necessary changes myself...
Quick Reply: Converter slip problem?
